Previous in Forum: Mechanical Fault with Toyota Avensis   Next in Forum: Refrigerant
GD2 Value of a Centrifugal Blower Rotor
07/15/2010 6:40 AM
How to calculate Moment of inertia and GD2 value of a Centrifugal blower rotor? How does these affect the starting time and starting torque?
Re: GD2 Value of a Centrifugal Blower Rotor
07/16/2010 1:38 AM
Recall the formula " T = I * Alfa ; where T is the driving torque, I is moment of inertia and alfa is angular acceleration.
For a driver such as a motor or a turbine, the max. torque is a limited value; so as "I" is increased, the angular acceleration will decrease. For this reason, the time taken to accelerate rotor from zero to its full speed will increase.
Large size industrial fans, such as power plant main exhaust fans as large as 4-5 MW, take very long time (20-30 seconds) to reach to full speed; also they are equipped with starting devices (e.g. Liquid Resistance Start) to limit the initial high current due to high slip.
Hope this is what you were looking for ! Any different opinion?
Good Answers: 137
07/16/2010 7:10 AM
Difficult to calculate accurately, and anyway blower manufacturer should be able to tell you.
But to get an idea, could take the mass of the rotor M and estimate the radius of gyration k. Then Moment of inertia I = M*k2. As a guide, for a solid cylinder I = M*r4/4 = M*(r/2)2, so k = r/2.
This gives I as M*r2 and this is the right value to use in calculations like angular acceleration = torque/I. In my opinion GD2 causes confusion.
Cheers..........Codey
Good Answers: 137
07/16/2010 8:30 AM
Sorry, should have written - "for a solid cylinder I = M*r2/4 "
01/18/2011 5:28 AM
ACCORDING TO WHICH CODE THIS FORMULA
Good Answers: 137
01/18/2011 8:31 AM
It doesn't come from a code, it's the result of a fairly simple calculation involving integration.
Codey
Belgium - Member - New Member
Good Answers: 21
07/16/2010 7:13 AM
  • RPM = ω x 2 x ∏ / 60 (rounds per minute = angular speed x 2 x 3.1415 divides bij 60 seconds )
  • ω = α x t (angular speed = angular acceleration x acceleration time. (we accelerate from stand still)
  • M = T x α (accelerating torque = moment of inertia x angular acceleration)
This means if you accelerate the blower rotor with a know torque, and measure the rotating speed after a know time, you can calculate the moment of inertia
08/25/2023 8:17 AM
<...Moment of inertia...> does not affect <...starting torque...>; it only affects acceleration time.
Anonymous Poster (2); Codemaster (3); PWSlack (1); rudy.leurs (1)
