Previous in Forum: Belt-Driven Fans   Next in Forum: Extension Spring Design
Fillet Welding
07/15/2010 11:28 AM
is fillet welding joint or butt welding joint to the branch welding between weldolet or sockolet with pipe ??
Re: Fillet Welding
07/15/2010 11:54 AM
If you are using a weldolet fitting, it is a butt weld. With a sockolet fitting, it is a fillet weld.
Mr.Ron from South Ms.
Good Answers: 38
Re: Fillet Welding
07/18/2010 7:26 AM
Banu.....
It seems to me that you are not aware of the purpose of codes and standards
Piping systems are designed and repaired in accordance with a generally accepted set of rules.
Contained within these rules are different types of acceptable branch designs and the welding requirements of each type.
As you would expect, the welding requirements for a low pressure branch is different than the requirements for a high pressure branch. Different types of materials (copper, steel, aluminum) have different strengths and different branch designs.
Hope that this helps.
-MJC
