Hello,
I need a device that will record a thermocouple as it gets immersed in molten steel (1600°C). Type S, 0-17mV in about 1 second.
Then I need to play it back for R&D purposes. What is the best way to do this?
It would be good to have two channels, the second channel may go up to 400 mV and be somewhat portable.
Battery operated would be good. 16 bit resolution if digitazing is necessary. 10 to 100 samples per second and good isolation. Need to save several wave forms, up to 2 minutes each.
Thanks in advance,
Carlos A. Moreira
R&D Technician, Heraeus
