Previous in Forum: Conserving Energy Use of Fans   Next in Forum: Electrical System Design of a Building
induction motor
07/15/2010 8:48 PM
what is the word "dynamic performance"means in induction motor?
padupoi
Re: induction motor
07/16/2010 3:10 AM
control of induction motors with maximum power efficiency as well as high dynamic performance by means of decoupling of motor speed (or motor torque) and rotor flux. For maximum power efficiency, the squared rotor flux is adjusted according to a minimum power search algorithm until the measured power input reaches the minimum. Since the motor speed is dynamically decoupled from the rotor flux, this can be done successfully without any degradation of motor speed responses. The controller depends on rotor resistance but not on stator resistance. However, the performance of the control scheme is robust with respect to variations in rotor resistance because an identification algorithm for rotor resistance is employed
