Previous in Forum: Microsoft Word Hexadecimal Format   Next in Forum: Suggest Some Good Construction Software For Electrical Projects
Omron HMI Model NS5-SQ00B-V1
07/18/2010 10:40 PM
Hi all,
Am planning to use the subject as operator panel station for siemens S7300 PLC, which has a MPI communication protocol, different from the omron which is RS232.
any advice on what com cable to use to have these two communicate with each other?
thanks and much appreciated
Re: Omron HMI Model NS5-SQ00B-V1
07/21/2010 10:36 PM
I must say to you good luck in getting an Omron HMI to talk to a Siemans PLC, I will watch to see how this is done. Normally you require similialar HMI and compatible PLC.
The exception I have found is Maple Systems HMI which apparently can communicate with mostly all PLC's.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
07/22/2010 1:04 AM
Hi Mike L,
Thanks for your concern. But someone in the Omron group suggested by using a cable type XW2Z-500T which will connect to a Simatic HMI adapter part#6ES7-972-0CA10-0XA0. I do not know for sure if this will work since other cable type from Omron also suggested to use NT631C-CN323-EU. Don't know which is which is the real thing.
Register to Reply 2 comments
