Previous in Forum: Solar Inverter Output Voltage   Next in Forum: Plastic Enclosure Over Metallic Enclosure
8 comments
Solar Power
07/19/2010 7:24 AM
Generally what are output voltages of solar inverter for the grid connected system? Because we have to connect it to grid so for that we have to have some specific voltages! I want learn about Grid Connected solar Power please suggest me any site for this! Thanks a lot. .
Good Answers: 804
Re: Solar Power
07/19/2010 12:11 PM
GlobalSpec is our gracious host. They can be used as a very nice search engine that removes many of the junk websites that come through with other search engines, I suggest you avail yourself of this service.
Like this...
Re: Solar Power
07/19/2010 3:55 PM
The solar inverter output voltage should match the grid voltage, whether it be directly or through the use of a transformer (generally for step-up applications where the grid voltage is in the kV range and the generated power is in the high kW to MW range).
Please consult the appropriate solar inverter supplier website for more details.
Re: Solar Power
07/19/2010 11:19 PM
Can you please suggest me some sites for the reference. .Thanx a alot. .
I have gone through some sites which says
• System Voltage – 590V
• Maximum DC current per circuit – 400A
• Output AC Grid Voltage – 400/460V
• Output AC Operating Current – 460A
Can you please explain significance of the above terms?
Re: Solar Power
07/20/2010 3:41 AM
If the panel output voltage were less than the system voltage, then current would not flow from the panel to the system.
Reference site.
Re: Solar Power
07/20/2010 11:54 PM
Thanks a lot for that!! :) :D
Re: Solar Power
07/20/2010 3:45 PM
The DC input and AC output parameters you have mentioned are just limiting and operational voltage and current limits and ranges that this specific solar inverter can handle.
Try the following sites first for a better understanding of solar inverters designed for grid-tie connection, I think that is what you are after
http://en.wikipedia.org/wiki/Solar_inverter
http://en.wikipedia.org/wiki/Grid_tie_inverter
http://en.wikipedia.org/wiki/Grid-tied_electrical_system
An internet search of "solar inverter" or "grid solar inverter" produces numerous sites which cover the concept basics such as the following....
http://www.backwoodshome.com/articles2/yago89.html
http://www.mrsolar.com/page/MSOS/CTGY/ce
etc.
Re: Solar Power
07/21/2010 12:01 AM
I want to know whether we can feed power that we got from solar arrays (After DC to AC conversion) directly to the grid that is coming at our home?
or there is some regulation that it has to be first Step Up and then it can be fed to Grid..
like 11kV or something?
Re: Solar Power
07/21/2010 3:37 PM
The answer is 'possibly' as it depends on local electricity regulations (both government and energy provider).
Yes, you can feed back into the grid directly onto the single or three phase supply from your home without the need to step up to 11kV (or other similar distribution voltage) as long as you are using a suitable grid-tie inverter, BUT you may not be allowed to legally or you may be allowed to but the energy provider (power companies) may not pay you for any power you provide back into the grid.
It is best to consult your local energy provider website and local government website regarding this as regulations and requirements vary from country to country (and in some cases from state to state). Additionally a local supplier (if any, you don't mention what country and/or state you are in) of this grid-tie solar equipment should be able to advise you.
Register to Reply 8 comments
atulj31 (3); jack of all trades (3); JRaef (1); PWSlack (1)
