Previous in Forum: Voting Philosophy   Next in Forum: Plain vs. Lifting Lever in Safety Valves
19 comments
Vibration Analysis
07/19/2010 8:16 PM
I am looking for an inexpensive setup to analyze vibration. It would be used for testing items such as engine mounts, shaft vibration or shaft mounting brackets. Any suggestions?
Michael
Re: Vibration analysis
07/19/2010 8:36 PM
How inexpensive? How accurate? Is it for comparison or characterization?
I have used a cheap microphone and an acoustic analyzer taped to pump housings, so I could identify specific frequencies and amplitudes. Then I'd compare this to a known good pump's profiles.
If you just need amplitude, use a db meter.
Just depends what you want to do. Have you looked for sound analysis software on the net?
07/21/2010 7:49 AM
Before you can implement you have to establish a benchmark, so you know the difference of what its supposed to sound like against when there is something wrong.
Good Answers: 27
Re: Vibration Analysis
07/20/2010 2:12 AM
You state what items you want to test, but you do not tell us what you want to know. If all you want is amplitude of displacement, accelaration or velocity then a simple SKF Vibropen would do. (There are many other manufacturers to choose from for similar instruments). On the other hand if you are wanting a full FFT spectrum analyser then B& K, SKF, Bently, Schenk and many others are available.
First decide exactly what you want to know and how you want to manipulate your results. This will allow you to buy (second hand equipment is cheap) something fit for purpose accompanied by the right software for your needs.
I have no special talent. I am only passionately curious. Albert E
07/20/2010 9:17 AM
Great information so far. I used to fly the MH-53 and we would have to run vibration tests on certain parts of the fuselage to determine if parts needed to be replaced or if drive shafts needed to be adjusted. Accelerometers (bi and triaxial) were attached to certain parts of the fuselage with cables running to a computer. The output was read on a computer in a frequency in Hz. I am working on a Dornier DO-335 condeptual design and the biggest problem is the aft engine and drive train. I am looking for a inexpensive but reliable vibration analysis setup to test the vibrations in this aft area.
Good Answers: 213
07/20/2010 11:41 PM
For a quick and dirty (and cheap) picture of magnitudes and frequencies, I would go with lynchlynch's suggestion of a microphone coupled to a digital oscilloscope that has FFT capabilities. You could probably use one of the software oscilloscopes available for computers for this (i.e., oScope in Linux- there are others that work in the other operating system). This will not give you 3-axis data, and I am not sure it would stand up in a court of law, but I have been able to pick out failing bearings, identify the sources of unwanted vibrations (assuming one knows a bit of the specifications of the various contributors), etc., and come up with isolation solutions that work.
Good Answers: 114
07/20/2010 11:54 PM
Nice
what other tools do you use?
I figured out Cheese will run my USB microscope camera rig
I'm finding most everything I could ever think of is on the software manager on my linux mint install.
I just flushed vista off my wife's laptop.
Good Answers: 213
07/21/2010 12:28 AM
What are you using for a camera on your microscope? I have a really nice Nikon tri-ocular that I used to have a B&W video camera mounted to, but I need to replace the camera objective lens, and what I used for a camera was straight video output. What I have seen from most of the cheaper "web cams" is limited resolution, but for my personal use, that might be OK.
Other tools- most important for me is QtDMM for recording multimeter readings (I once wrote a VBA macro for Excel to do the same thing)- set up like a digital chart recorder to give me time records. I have found that Ubuntu automatically recognizes my Keyspan usb/RS232 adapter, which is something Windows won't do- one needs to add drivers for that...
I have an external digital oscilloscope (Link Systems, Inc.) that is better than the xoscope solution (no worry of burning up the sound card, which is integrated into the motherboard on my laptop)- but I have to run that in VirtualBox since I don't have software that works in Linux...
And a small data logger that is more of a toy (originally sold as an educational tool for high school science courses), but is programmable and serves nicely for my experiments with stepper motors...which I am doing with the idea of building my own 3D printer one of these days...
I have lots of toys in my laboratory, but way too little time to play with them...
07/21/2010 2:01 AM
or another option ..... pending on how many test you wish to perform ......
Solidworks coupled with Cosmos - motion can give basic information without distroying anything ...
Anthony@alno
www.alnoproductservices.com.au
07/21/2010 5:49 AM
The Motorola Droid phone has an App that does that.
07/21/2010 7:00 AM
Here is a link to Analog Devices.They have a relatively inexpensive vibration sensor that is easily interfaced to your computer: ADXL 105 Chip.
Here is an excerpt from the website:
The primary opportunity posed by the low cost and increasingly high performance of these devices is to enable new applications that weren't possible before. Although there is also a potential for replacing other means in existing applications, there is no reason to believe that designers who design or customers who purchase precision instruments will suddenly change to a new technology strictly on the basis of cost, as there are other important considerations in the precision instrumentation business.
However, there is a limitless opportunity to develop new or expanded uses of precision sensors. For example, the new technology may allow designers to instrument full-time monitoring of every machine, motor, pump or compressor that a manufacturer makes. New low cost, precision sensors with their fully signal conditioned output can reduce the cost of each point in a real-time monitoring system from $1000 to under $100. That kind of cost reduction makes feasible new uses for sensors that were not possible before. For example, a manufacturer of industrial equipment can now economically produce a "smart motor", which has high-efficiency drive electronics employing DSP for speed control, and accompany it by a low-cost machine-health conditioning module to increase energy efficiency, improve up time, reduce maintenance cost, and thus lower the end customer's total cost of ownership.
http://www.analog.com/library/analogDialogue/archives/33-06/adxl105/article.html
Good Luck
07/21/2010 7:14 AM
Equipments are available depending on the data and analysis you need.
However, in case you are stuck up in a place without any of these equipments, a simple screw driver can give you a feel of the vibration - provided you are close enough to the vibrating point.
One end of the screw driver will be touching your ear and the other end touching a convenient area near the vibrating point.
I found this cheapest technique useful many times.
Rajan
Good Answers: 213
07/21/2010 10:44 AM
Known as the "mechanics"s stethoscope"- very good solution for a quick analysis...
Good Answers: 114
07/21/2010 12:00 PM
A big screw driver works pretty well too, if it sounds like gravel, there may be a problem
Here's a place to find out about more Iphone apps
http://www.theonion.com/video/new-apple-friend-bar-gives-customers-someone-to-ta,17693/
Good Answers: 11
07/21/2010 7:35 AM
The iphone has some vibration analysis apps. I don't know how good they are but if you already have an iphone then you won't find any other tool cheaper than purchasing an app.
07/21/2010 9:20 AM
Same query here. I'm looking for similar equipment for open gear (girth gears) vibration analysis. Need inputs pl
07/21/2010 1:41 PM
You will need an accelerometer connected to an A/D converter whose output is fed to an FFT program in order to measure the frequencies and harmonics. Be absolutely sure to use an anti-aliasing filter to condition the accel output before going to the A/D.
The best route is to go to used sources to buy a commercially made vibration analyzer.
12/02/2012 10:49 PM
The Apple iPad has a full spectrum vibration analysis app with external accelerometor's. This is a very inexpensive solution and I think they have several apps to suport balancing, bearing, and gear defect frquency's. If you google iPad vibration analyzer there are several videos on the subject.
12/03/2012 8:19 AM
If its the vibration app I'm think of, there was a compliant that there was no unit specification on the vibration, allot of charts but no units.
There was something similar with the accelerometer app
12/03/2012 2:51 PM
I'm not sure which app you were looking at - the one I'm familiar with - VibePro - captures frequency in "Hz/CPM" - it is pretty well marked to show that off. There may be other apps I'm not familiar with.
Register to Reply 19 comments
Anonymous Poster (2); Anthony@ALNO (1); cingold (1); cwarner7_11 (3); E=MC^2 (1); Garthh (2); HiTekRedNek (1); Kaisan (1); koustuvmohanty (1); lyn (1); phoenix911 (2); tchaten (1); thoenig2 (1); WoodwardDL (1)
