Previous in Forum: Heated Bolt at Transformer Conservator Tank Flanges   Next in Forum: Voltage Improvement By Using Capacitor Bank
PLC - Siemens
07/20/2010 5:41 AM
I have a B-R plc made in Austria which has an associated touch pnael.The touch panel is faulty thus I cant interface with the machine.The available touch panel is the Siemens Simatic touch panel.Can interchange the twe , the power supply and the signal cables are the same.Will the display in the Siemens touch panel be the same as the older one
Pascal mbithi
Re: Plc
07/20/2010 5:49 AM
What does Siemens have to say on the subject?
Re: PLC - Siemens
07/20/2010 1:09 PM
Hi, yes you can,but first of all you have to sure that ratting is same,then you do.
Register to Reply 2 comments
