Previous in Forum: How To Convert Euro 3 Engine To Euro 4?   Next in Forum: 2002 Dodge Neon Rim
Good Answers: 137
Mondeo Fuel filter
07/20/2010 6:30 AM
Something on my 2004 petrol Mondeo might be of interest. Decided to change the inline fuel filter. Should be every 50000 miles and now done nearly 120000. In theory it should have been changed once when it was a company car (mine, I bought it from co) but I suspect it hadn't and the one I took off was a Ford part, suggesting original. No sign of any problem so thought I was maybe overcautious, but for £6 why take a chance?
Interesting thing is before change mpg was about 38 after a decent run but now it has gone up to > 42 mpg (trip computer for both, if it can be believed). At that rate it will soon pay for itself, apart from benefit of protecting the injection system. Anybody else noticed this? I'd have thought if anything it would use more fuel as less restriction, but I'd hope the kit was good enough to avoid this.
Another thing – the Haynes manual says to remove the fuel pump fuse and run the engine till it dies, to depressurise before disconnecting pipes. But it doesn't say which fuse, and the fuel pump doesn't appear on any of the wiring diagrams! No problem as the top of the pump is under the back seat and it's easy to pull off the connector. But on reconnecting, the options on the trip computer had been reset. Don't know if it would be same if just the fuse removed. Also noticed the mpg reading is livelier. Previously if it was on about 35 mpg cos hadn't been far recently, on a run it would rise by 0.1 mpg over 20-odd miles, too unresponsive to be any help for economical driving. Now it's pretty good, better than some I've seen where it flickers about too much to be any use – 10 mpg when you accelerate, 999 when you ease off or go downhill.
When refitting the fuel pump connector, it seemed to go on with a more positive click than I expected, maybe an iffy connection is the explanation, it feeds the tank level sender unit as well as the pump.
Apologies for waffle, but it might interest somebody!
Codey
Re: Mondeo fuel filter
07/20/2010 6:39 AM
Has the replacement filter got any magnets in it?
07/20/2010 7:11 AM
Splarf...snort...
Damn...
Tea in the keyboard again.
Good Answers: 137
07/20/2010 8:34 AM
No, and no HHO generator either
Good Answers: 19
Re: Mondeo Fuel filter
07/20/2010 11:33 AM
This is very interesting. It sounds like you had a moving average and perhaps it had been driven previously without fuel economy in mind, they aren't paying for the petrol and that meeting is more important than the environment. Now it would appear you have reset a counter and it is you producing the average not the previous drivers. If this is so, then the improvement in fuel consumption is a result of the new average rather than the replacement fuel filter. - just a thought.
07/21/2010 1:32 AM
Anecdotal evidence to support the increase in mileage so take it for what it is worth.
Two cars years apart from diffefrent manufacturers. Car number one was a Plymouth Cricket (70s in NA). The car would not run right on the highway, lacked power and would just flat out quit on some trips. the fuel filter by the engine was repalced regularly. What I didn't know was that there was another one back by the fuel tank. Replaced the second one and all driving problems disappeaered and fuel economy improved considerably.
Car number two is a 2001 330Xi that I bought used. I had a 250 km drive to get home. Fuel economy was 8.9 litres per 100 km. Took the car in for a major service which included changing all fluids and filters. Once that was done, I left on a 3,000 km trip. Fuel economy for the trip, including driving in town, on the highway and in the mountains with a 100 kph average speed was 8.1 litres per 100 km.
So, yes I do believe that changing a partially clogged fuel filter will improve mileage significantly.
Good Answers: 137
07/21/2010 4:37 AM
Thanks writer, if I'd known that I'd have changed the filter sooner!
Codey
Register to Reply 6 comments
Codemaster (2); HUX (1); JohnDG (1); user-deleted-1105 (1); writer (1)
You might be interested in: Fuse Holders, Fuel Cells
