Previous in Forum: Plain vs. Lifting Lever in Safety Valves   Next in Forum: Level Indicator
Battery Room Flowmeter Selection
07/20/2010 7:58 AM
Hi,
There is a Battery Room With Exhaust Fan -Motor with Duct diameter 8.0" Typically ) arrangement ,
I would like to monitor the flow at the Discharge side of the duct--- which flow instrument (switch type preferably coz i dont know process conditions ) should i use for this application
we are not in a position to have straight run requirements
Regards
jose john
Re: Battery Room Flowmeter Selection
07/21/2010 3:45 AM
A paddle-type switch might be applicable. Endress + Hauser (usual disclaimer)?
07/21/2010 4:06 AM
Thank You,I really needed some inputs on that
Regards
Jose
07/21/2010 7:45 AM
A stack switch like is used on gas-pack heat systems should work.I presume you simply want to know if you have flow or not, and to activate a switch.
These stack switches are commonly available at any HVAC supplier, and fairly cheap.
Canada - Member - New Member
07/21/2010 7:46 AM
I've had better experience with solid state sensors similar to this one by IFM. I'm sure other manufacturers make them as well. There are no moving parts and the setpoints are adjustable.
Best of luck
Knowledge makes what was impossible, seem easy.
07/21/2010 5:17 PM
Air flow can be proven by a differential pressure switch, plumbed with flexible tubing to either side of the fan. Usual problem is knowing what range switch to pick. If you can't beg, borrow, or steal a DP gauge, you could even make a water U tube manometer from a piece of flexible transparent tubing, so you can get an idea of what range you'll need.
http://www.dwyer-inst.com/Products/TOC.cfm?MainCategory_ID=1&iCurrentCategoryID=292
Carl_E (1); Elroy (1); HiTekRedNek (1); josej (1); PWSlack (1)
You might be interested in: Duct Heaters, Air Hose and Air Duct Hose
