Previous in Forum: Compressor Lubrication   Next in Forum: Refrigerant R-407C
Metal caps for ducts
07/20/2010 11:28 AM
Colleagues, I wanted to ask someone who can sell metal caps for ducts, i have to take pitot traverses but I need after that to seal the hole (3/8" in diameter), I need metal caps not plastic ones
appreciate the help
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Re: Metal caps for ducts
07/20/2010 11:37 AM
Hello Frank-Jazz.
Do you mean this sort of thing?
If yes, widely available. This image from Grainger. They will sell to you.
Usual disclaimer applies.
07/26/2010 11:29 AM
Is more like this one but in metal, is to tap a black iron duct for a kitchen grille exhaust regards
07/26/2010 11:45 AM
There are such things:
This is very common, but only in 3/4" Ø.
This is a finger pull for a closet door. There may well be similar items for other uses that are the smaller size you seek.
Good Answers: 58
07/20/2010 1:49 PM
Frank,
How about two washers of proper size with a screw/nut through the center.
If condensation/rust is an issue, use the same set up in stainless steel.
If condensation seepage is an issue use a thin rubber gasket in between the washers.
If there is no way to reach behind to get a washer on the inside of the duct, use a washer/screw/toggle bolt set-up.
KJK
07/27/2010 12:10 AM
Do you have a picture?? Im little bit lost
Doorman (2); Frank-Jazz (2); KJK/USA (1)
