Previous in Forum: Plain Washer Quality Grades   Next in Forum: Quality Control Inspector
12 comments
Wood Veneer Quality
07/20/2010 5:10 PM
Is anyone familiar with the process of producing wood veneer? More specifically does anybody know of any quantitative means for evaluating the quality of veneer besides checking its thickness and width? Prior to the knife peeling the veneer from the block, a pressure bar applies pressure to the wood to hlep keep it from splitting. All of the references that I have found say that it is the lathe operator's duty to inspect the veneer to make sure that quality product is being produced. Is there a way to verify that the correct pressure is being applied that doesn't involve a subjective inspection?
Thanks.
"Obviously you're not a golfer." - The Dude
Pathfinder Tags: lathe pressure bar quality veneer wood
Re: Wood Veneer Quality
07/20/2010 5:44 PM
From your original post, I cannot tell if you are producing rotary, plain sliced, rift cut, quarter sliced, or ribbon cut veneer.
The short answer to your question is: Yes, there is a way to verify veneer quality without subjective inspection. The bad news: Unless you are producing several million US dollars per quarter of finished product, these methods are well beyond your reach.
Can you tell us a few things: Wood species, veneering methods, anticipated volumes, anticipated markets and market penetration, equipment and plant available... those sorts of things.
Oh, in a production setting, the lathe operator has very little to do with the veneer quality. Is this a small peeler veneer mill? It comes into play a little then.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
07/20/2010 7:59 PM
I grew up in Oregon, went to school in a timber town, pulled green chain in a lumber mill, apprenticed with a millwright for a while, and did not have a clue as to the different veneers!
GA from me cause you taught me something!
Give me enough duct tape and I can fix anything!
07/20/2010 8:25 PM
Is this your alter-ego Veneerman?
Good Answers: 243
07/20/2010 10:19 PM
Sie wissen Alles nach veneer! Milo
07/21/2010 9:10 AM
Hallo Milo und freunde.
Ja, das furnier und ich wir sind freunde (Yes, veneers and I are friends).
Thanks, guys. Yes, I have seen the training video about wood veneer. This is a pretty big part of the door business. We will see if pauls 14 has some more for us.
07/21/2010 3:52 PM
We are using a relatively small rotary peeler style mill. We work with aspen and birch to make small sticks and shapes for arts and crafts. We pull around 10,000,000 linear feet of veneer each year. The plant and most of the equipment are fairly old – old enough that I won't be able to tell the lathe/peeler manufacturer without some serious digging. Depending on the product line, we do employ a vision system to grade veneer based on the knots in a sheet.
Although the methods for verifying veneer quality that you mentioned may exceed our budget, could you discuss them?
In a larger setting, how is the pressure applied by the pressure bar controlled, and how is it checked?
Doorman, thanks for you response. By the way, are you in Fargo, ND?
07/21/2010 4:52 PM
"Although the methods for verifying veneer quality that you mentioned may exceed our budget, could you discuss them?"
Optical scanner and recognition technology. The technology is basically the same as size and color selection/rejection of any bulk product, and adapted to wood veneer. This type of system represents a fairly large capitol outlay (purchase and initial setup, maintenance, programming, and floor space), and lends itself well to large production runs. If I digest your estimate of ten million LF of veneer, that works out to about 20LF per minute. The peelers I have seen run about (I am guessing) 400-600LF per minute (it really shoots off of that knife!). This also allows semi-automated runs, which allows for a lot more up time (production). The scan equipment locates and identifies heartwood or sapwood, burls, worm holes, knots (open or closed) and pin knots, bark pockets, splits, mineral streaks... the graded flitches are diverted to a number of different lines as appropriate for each grade of veneer. All of the veneer, even if not grade-able, is used somewhere... there is very little waste.
"In a larger setting, how is the pressure applied by the pressure bar controlled, and how is it checked?"
I am not well schooled in the veneer peeler equipment available, but I cannot recall a 'pressure bar'. Is this the knife? I do know that veneering is quite an art, and those well accomplished in the skill make it look easy. What veneer thickness are you producing? Door skins are about 1/50".
I hope some of this is useful. Good bye, and hope to hear from you soon.
From Fargo, ND, USA, your friend Doorman
07/22/2010 5:38 AM
I don't know any thing about this sort of thing but it sounds as though the arrangement looks something like this:-
pauls_14 is wondering how to control the force on the roller which compresses the wood just before the blade.
Paul, Is the picture approximately correct?
07/22/2010 11:43 AM
I was wondering about Fargo, ND because up until 2009 I worked in Fargo and Hawley. Are you in the wood industry in Fargo, or is that from past experience? - I can't really think of any employers where that might come into play except maybe one of the cabinet makers or Marvin/Integrity.
07/21/2010 11:20 PM
In a veneer mill w/lathe now days 1300 to 1600 lineal feet a minute is routine. The roller bar at the lathe pressure is regulated with hydralics according to product being peeled. Scanners are set up pre clipper and they just grade for width that panels of veneer can be cut into. Actual veneer grading is still done basically by hand by trained personel at least at our plant any way. I guess this doesn't answer your questions exactly but I hope it gives you more info.
07/22/2010 8:50 AM
Information relative to veneer processing and specifications can be found at:
http://www.hpva.org/ (hardwood plywood veneer association)
07/22/2010 10:01 AM
Thank you all for the responses.
Randall's diagram is fairly close. The pressure bar contacts the spinning block just ahead of the knife. When properly adjusted, it prevents splitting and cracking in the veneer. We hand pull veneer up to 0.15". Our peelers don't run full time, so they are capable of around 200 feet per minute, depending on the thickness. The thinner veneer is peeled on an automated system.
Register to Reply 12 comments
Anonymous Poster (1); Daddio926 (1); Doorman (3); farmatt (1); lyn (1); Milo (1); pauls_14 (3); Randall (1)
