Previous in Forum: Design of Rubber Band Powered Air Plane   Next in Forum: Gas Turbine
Insulation Thickness
07/21/2010 6:47 AM
One circular pipe having operating temp.529c and surface temp. 450c pipe outer dia is 660mm. What is thickness of insulation?
Good Answers: 27
Re: insulation thickness
07/21/2010 7:57 AM
Is this really 6" - as the A said to the B.
Don't you think you should give us some clues, like the material properties of the insulation, desired temperature of the insulation ...............????????
I have no special talent. I am only passionately curious. Albert E
Re: Insulation Thickness
07/21/2010 9:00 AM
If the insulation material were one of those new-fangled aerogels, a few mm would do.
Good Answers: 38
07/21/2010 6:38 PM
According to my recollection, with an outer surface temperature of 450 C, I believe that you would need about 4 to 5 inches of calcium Silicate.
Its OK for use to ~540 C
Look at www.engineeringtoolbox.com
07/21/2010 11:00 PM
Homework!
Good Answers: 11
07/22/2010 7:46 AM
I agree. Who pulls the operating temp and finds the surface temp of a line without knowing the calculation for optimum insulation thickness?
07/26/2010 4:55 AM
I sure Rock wool or Calcium Silicate , thickness 2 1/2" is ok for this temp & Pipe OD
Anonymous Poster (2); cingold (1); Kaisan (1); MJCronin (1); PWSlack (1)
