Previous in Forum: Convection and Radiation of Heat Through a Medium   Next in Forum: Evaporation Rate and Temperature of Gasoline
Materials Question: Hastealloy C-276
07/22/2010 1:29 AM
Hi to all,
can anybody provide the difference between the materials S31254 (Austenitic SS) and Hastealloy, if not what will be the alternate material for S31254.
Thanks,
Siva
Re: Materials Question: Hastealloy C-276
07/22/2010 1:54 AM
It's spelled 'Hastelloy', and a Google search on this word will yield a number of answers.
It's well worth looking at the Cole-Palmer materials compatibility database for examples of appropriate applications of these materials, if the specific application is not to be revealed here.
Good Answers: 150
07/28/2010 5:32 PM
UNS S31254, trade name 254SMO is an iron based austentic stainless steel with 6% Moly, .2% Nitrogen, and .75% Copper on top of the 18% Nickel and 20% chrome. It's corrosion performance in most applications is about as good as any iron based stainless can get, but Hastelloy C-276 has it beat, as does Inconel 625 and Inconel 725 or Alloy 625+ (which are heat treatable grades of 625 which are much much stronger.)
BUT all of the other alloys are Nickel alloys and are much more expensive.
But for us to suggest an alternative material, first we need to know the application and the environment and the strength level required.
http://www.outokumpu.com/35043.epibrw
http://www.haynesintl.com/c276hastelloyalloy.htm
http://www.specialmetals.com/documents/Inconel%20alloy%20625.pdf
http://www.specialmetals.com/documents/Inconel%20alloy%20725.pdf
http://www.cartech.com/ssalloysprod.aspx?id=1930
Who is John Galt?
12/06/2012 1:10 AM
That means hastelloy is a nickel based super alloy?
Good Answers: 150
12/06/2012 9:43 AM
indeed it is.
Who is John Galt?
Anonymous Poster (1); PWSlack (1); Rorschach (2)
