Previous in Forum: Locking Mechanisms   Next in Forum: Pipeline Resistance
Chilled Water Piping
07/22/2010 6:11 AM
Dear all,
what difference does it make by installing concentric or eccentric reducers in the horizontel chilled water piping network.
Regars
Mirza
Pathfinder Tags: chilled water system
Good Answers: 61
Re: CHILLED WATER PIPING
07/22/2010 7:21 AM
None.
But then, we don't know why you are making a change in the line size.
Maybe you need to explain the situation better.
Do it once and do it right
Re: Chilled Water Piping
07/22/2010 11:38 AM
Nothing except that upstream pipe & down stream pipe are not co-axial
RK
Good Answers: 38
07/22/2010 8:19 PM
The selection of reducer type (concentric or eccentric) only is important on the suction piping just upstream of a pump
07/23/2010 8:40 AM
Sres cuando se se necesita menores caudales se emplea
reducciones de diamentros y la seleccion concentrica o exentrisa
para una cañeria Horizontal se usa la excentrica ,para tener igual BOP
esto es debido a que tenemos alineados los soportes
Saludos a todos
Ing Galindo, A
07/23/2010 3:00 PM
if you fitt eccentric reducers the pipe should be at the top so that the larger pipe will act as a sludge trap for any sediment in the line.
As to the flow rates it will not matter what type of reducer you use.
07/23/2010 8:33 PM
your goal would be to reduce turbulence prior to admission.....at the pump or valve
klearzen
Register to Reply 6 comments
alberto galindo (1); Anonymous Poster (1); brkmech (1); klearzen (1); MJCronin (1); PennPiper (1)
