Previous in Forum: Chilled Water Piping   Next in Forum: Centrifugal Pump Design
Pipeline Resistance
07/22/2010 6:14 AM
I have a ramifying network of pipeswhich join to a main duct of greatest diameter. At the end of the branches are suction mouths (56). The suction force comes fromt a centrifugal fan. Sample archetype:
My problem is i want to be sure of what will happen to the system load curve and the flow rate in the following conditions:
1. With the suction firce constant, 15 suction mouths are closed completely
2. in the same fan condition, all suction mouths are closed
3. how will system load vary as a function of the number of suction mouths open
4. what will be the corresponding variation on the flow rate along the pipeline, before and after the fan (upstream and downstream)
5. for 56 mouths i have a flow rate Q1. if i wish to have the same flow rate for 48pots, what will be done to the pipeline or the fan
Re: Pipeline resistance
07/22/2010 7:39 AM
  1. The flowrates elsewhere on the network will increase, and the inlet pressure to the fan will reduce.
  2. The flowrate will become zero, in which case it is time to turn the fan off.
  3. This can be established by testing.
  4. ditto.
  5. Either:
    1. modulate the speed of the fan so that the flowrate is maintained. Fit a variable speed drive to the wiring feeding the fan, or
    2. Fit a damper in the fan pipework so as to throttle the flow through the fan while it is running.
Re: Pipeline Resistance
07/23/2010 12:59 AM
This problem has been thrashed to death in a number of related threads, mostly involving lots of overthink without understanding simple things. Put a pitot tube in a representative location, or maybe an "Annubar," using this to control a fan VFD to maintain near-constant pressure difference, and hence flow.
07/23/2010 2:51 AM
Actually the problem raised here is the fluid mechanics theory behind such ductwork. That is the behaviour of the global system resistance to flow as suction mouths are progressively closed.
07/23/2010 8:27 AM
Este es ploblema tipico de mecanica de fluidos, y su calculo tendra los siguientes pasos
1-datos del sistema:
curva del ventilador, presion caudal
Curva de los Dampers
Diamentros de los ductos
Ascesorior, te, reducciones,etc
2- se hace correr el calculo para las distintas hipotesis de trabajo
con Dampers cerrados
con Dampers totalmente abiertos
con dampers regulados a los caudales apropiadas
si se seleccionan los nodos apropiadamentes se puede determinar
la presion y caudal en cada nodo
saludos a todos
Ing galindo, Alberto
Register to Reply 4 comments
alberto galindo (1); Lama Sinto (1); PWSlack (1); Tornado (1)
