Previous in Forum: Difference Between Rz 40 and Ra 3.2?   Next in Forum: Chilled Water Piping
Locking Mechanisms
07/22/2010 5:59 AM
I've been asked to redesign a tripod arrangement that is too heavy. It's made from steel. I'm going to use carbon fibre. My problem is not the carbon fibre, but a locking mechanism for two of the three legs. Currently this is another bar that slides along the shaft and is locked into place when the tripod is open. I'm looking for a mechanism that will securely lock the two legs in position and be straightforward to unlock and let the legs come together.
Bearing in mind that the conditions in use have a lot of vibrations and are manhandled.
The tripod looks similar to this.
Re: Locking Mechanisms
07/22/2010 11:56 PM
Curious to know, why lock two legs only and how this tripod will be stable if only two legs are locked.
For three leg locking standard method of telescope tripod is good.
07/23/2010 6:41 AM
If you notice the front leg, it comes out and rotates about 140 degrees. The weight of the contraption holds this in place. The other two leg have a sideways movement. This is only about 30 degrees. The weight of the contraption does not lock this movement, as it is acting in a different direction to the leg movement.
Good Answers: 213
07/22/2010 11:59 PM
Are you sure the carbon fiber matrix is going to be able to withstand the shock and vibration loads for which this tripod was designed? Also, bear in mind that the weight of the tripod also helps keep the business end of your system on target...
07/23/2010 6:48 AM
I hope so. I am more concerned about locking mechanisms failing under the vibrations. I can always make the legs more robust. In reality the actual time spent under the high vibrations is very low. It will be given to soldiers.
This reminds me of a little story about a carbon fibre spade that was designed for the army. The prototype was made and given to the army to see if it was up to the normal standards a metal spade wold go through. Unfortunately the guy handing it over left it with them and said "There you go, see if you can break that!".
This was taken as a challenge. The next day a broken spade was returned with the advise. "That took us a while until we ran over it with a tank". "Yes we can break it". "Do you have any more as they are really light and better than our metal spades".
Good Answers: 22
07/23/2010 12:18 AM
How about a simple folding brace with a lock clip?
Hmmm, that might be a bit more difficult if the legs are at an obtuse angle to each other (but still could work with a swivel attachment point on the legs)
Tonyma
Good Answers: 204
07/23/2010 12:19 AM
that looks like a tripod for a .30 cal machine gun. as much fun as it might be to help, I won't if it is a weapon base. (pacifist)
Chris
Good Answers: 74
07/23/2010 4:26 PM
Alexa, help us!!
The Twain Has Met
Register to Reply 7 comments
chrisg288 (1); cwarner7_11 (1); gsuhas (1); ky (1); OldTechNewToys (1); Worrier (2)
