Previous in Forum: SDI12   Next in Forum: Load Cell for Batching Plant
Good Answers: 29
Compressor selection
07/23/2010 11:10 AM
I need to size a compessor purchase for an upcoming project. The demand for the instrument air I'll need is;
10 liters/min @ 3 barG +
20 liters/min @ 3 barG +
1 liter/min @ 2 barG
How many CFM @ 50 psi should I shop for?
Thanks.
Re: Compressor selection
07/23/2010 12:02 PM
1 CFM = 28.3 L/min
3 barG = 43.5 psig
31/28.3 = 1.10 CFM
Something like this would probably work.
This is basic knowledge for me - not much experience, so wait for some of the others who will have more experience to weigh in before buying. (Just to be sure)
Mike
Good Answers: 29
07/23/2010 12:25 PM
Thanks! Actually, that's dead on with what I came up with using this. On a more specific note, the device in question is a COSA 9600 calorimeter. A shop compressor with much more capacity than we calcuated was being emptied! As of today the thing is on it's way to the shop in Houston for eval. Have a good weekend.
Good Answers: 67
07/26/2010 6:33 AM
Your requirement appears to be not clear. normally the air requirement is expressed in Nm3/hour OR SCFM. So, if it is in different form, convert it in any of these two & ask the compressor supplier. They will guide you.
Here some more suggestion for you:
1) Compressor disch. pressure should be minimum 50 psi(g).
2) As, use is for instrument air, think of installing driers too.
Register to Reply 3 comments
Mikerho (1); pritam (1); RDGRNR (1)
