Saw the thread regarding argon for solar heating. My question involves photovoltaics. I'm making some 70w panels with plexi, aluminum backing and spacers, and poly cells. The issue is that i live in a humid area, and some moisture will be in the panel, even after sealing (with silicone II). The moisture in the panel will invariably collect on the plexi and lower efficiency. What about the possiblility of adding a couple of schrader valves, using one to pump air out while adding argon to replace it?
Also, does silicone II hold up long term for keeping the seals airtight? I've thought of grinding a shallow rabbit down the middle of the 1" wide/ 1/4 " thick spacers to deposit the silicone. It all clamps together with stainless screws run through and tightened with washers and nuts. The panel from bottom to top is: sheet aluminum, spacer, plexi (3/16"thick), spacer.
