Previous in Forum: Quick Connects   Next in Forum: Need Help Selecting Auto Battery Charger/Tender
R-410A Refrigerant
07/26/2010 11:01 PM
the newer 410a refridgerant is being used in existing air handlers with a valve change. Is the evaporator compatible with the higher pressures?
Re: R-410A Refrigerant
07/26/2010 11:39 PM
07/27/2010 12:30 AM
The evaporator is on the low-pressure side, and not so likely to have a problem. The condenser, on the other hand, is on the high-pressure side, and is more likely to have a problem. In any case, it all depends on the pressure ratings of the specific items involved. In addition, the compressor may be electrically overloaded. See the other recent thread on R-410A.
07/27/2010 5:43 AM
What was the old fluid?
What does the original equipment manufacturer have to say on the topic?
07/27/2010 8:13 AM
This is on new equipment originally produced for R22 but sent with the newer R410
a valve with a 410a condensor.
Register to Reply 4 comments
billiamt11 (1); lyn (1); PWSlack (1); Tornado (1)
