Previous in Forum: Capicitor Bank - DG   Next in Forum: Synchronous Machines
Definition of Ir and In in MCCB
07/27/2010 4:10 AM
Please, give to know the differences between Ir and In in MCCB according to IEC recommendation 974-2.
Thank you in advance
Re: Definition of Ir and In in MCCB
07/27/2010 5:24 AM
→ British Standard 7671.
India - Member - New Member
Good Answers: 164
07/27/2010 7:33 AM
Please see this comment from JRaef on another thread: http://cr4.globalspec.com/comment/561110/Re-What-is-the-Ith-Ir-at-MCCB-stand-for
Extract below for ready reference.
Voltage
  • Ue = Rated operational voltage
  • Ui = Rated insulation voltage
  • Uimp = Rated impulse withstand voltage
Current
  • In = Rated current
  • Ith = Conventional free –air thermal current
  • Ithe = Conventional enclosed thermal current
Short -Circuit
  • Icm = Rated short circuit making capacity
  • Icu = Rated ultimate short circuit breaking capacity
  • Ics = Rated service short circuit breaking capacity
  • Icw = Rated short time withstand current
Trip unit
  • Ir = Adjustable overload setting current
  • 1.05xIr = Conventional non –tripping current
  • 1.30xIr = Conventional tripping current
  • Isd = Short time delay tripping setting current
  • Ii = Instantaneous tripping setting current
i am curious. Since you mention IEC 60947-2, why did you need to ask this at all ?
04/28/2020 2:43 AM
Is there a prize for getting it right?
07/23/2020 9:30 AM
Ir: Rated current which is selected based on load current and protection settings.
In: Rated current of MCCB or frame size.
Ex: 160A MCCB with 100A TMD protection. Means 160A frame size of MCCB (In) and it has protection function for Ir:100A where you can either set the protection from 0.8..1.2xIr or fixed (i.e 100A)
You don't understand anything until you learn it more than one way.
Register to Reply 4 comments
kvsridhar (1); PWSlack (2); vijaymail_electrical (1)
