Previous in Forum: Statement of Dissociation - JohnDG is not jdg   Next in Forum: Wiring Diagram for 2 HP yl90l-4 Electric Motor
Pipe coatine wastage estimation
07/27/2010 11:51 AM
HI , We got a project of coating pipes 2" dia and 800 sq.m total area . we have encountered wastage of 60% of paint . we are using Graco extreme with Nozzle size 219
any idea what is the industry standard for pipe wastage percetage , how to reduce the wastage . Thanks
Re: Pipe coatine wastage estimation
07/27/2010 12:07 PM
Hello yusman.
An overspray loss (wastage) of 60% on an irregular shape is not uncommon. We experience about 35-40% loss on regular surface (flat steel door) and about 50% on irregular shape items we occasionally paint.
Are you painting inside, away from wind? A windy work area wastes a considerable amount of material. Other than that, careful application.
07/27/2010 4:34 PM
You could use a 4" roller. They also sell coating mitts, slip it on your hand dip and go. You could try using a 213 or 211 tip, it has a smaller orifice size and will put out a finer spray. If your doing a lot of this, the best answer of all is to invest in an electrostatic spray machine, waste will be less than 10%.
Register to Reply 2 comments
