Previous in Forum: How to Estimate Tooling Temperature at Oven Exit   Next in Forum: Forced-draft Boiler Vrs Induced Draft Boiler
Compressor Sizing
07/28/2010 12:41 PM
How should I know the size of compressor if there is no capacity mentioned? Nothing is written over it what will be the ton or btu of compressor in sealed and semisealed. Please help me define it.
Re: compressor sizing
07/28/2010 1:00 PM
Can't be done. Even if you gave us some idea of the type of compresser, size of compresser and motor information, which you do not.
How can you possibly expect an answer to such an impossibly incomplete question????
Tin foil hat?
Good Answers: 29
07/28/2010 1:05 PM
If it looks big, it might be alot.
07/28/2010 1:20 PM
I think the rule of thumb is 1,000 Btu per foot of circumference/the power cord length in inches.
Re: Compressor Sizing
07/28/2010 11:04 PM
The rule of thumb is for every horsepower on the motor you get 4 CFM from the compressor. This is the rule of thumb for reciprocating compressors. eg.. 5 HP = 20 cfm good luck!
07/29/2010 10:56 AM
First of all-- what is this compressor doing--is it air compressor, air conditioning compressor 0r ?. Is it open, hermetically sealed or ?
If a motor is attached to it and its HP is known--we can get cfm delivered by it-when it is air cond. compressor. when Motor is small, fractional or close and it is hermetically sealed it is an air cond. or refrigeration compressor. Air compressors are not hermetically sealed.
There are so many IF's. We must know the purpose this compressor is there for. Is it connected to ductwork to deliver air to a space or for ?? dompressed air to a process etc.
Good luck. Please share this small research to help us find out.
Good Answers: 19
07/29/2010 11:09 AM
If you are using the compressor as part of a refrigeration system the rule of thumb depends on the cold temperature. ASHRAE "suggests" 0.87 to 3.25 HP/ton cooling. Capacity will vary significantly based on condensing temperature, and desired evaporator temperature.
Give us more information and some one can develope a better answer. Is this for cooling, compressed gas, or what? What are temperatures? What is the working fluid? What is the compressor pressure rise?
Anonymous Poster (1); lyn (2); RAJ089 (1); RDGRNR (1); Ried (1)
