Previous in Forum: Elastomeric Duct Liner   Next in Forum: Fuel Alcohol Distillation Through Stripper Column
Clear Acrylic Lampshade
07/28/2010 8:03 PM
Is there a liquid acrylic that I can use in a mold for a lampshade which will be heat resistant? I am in north FL. Thanks
Re: Clear acrylic lampshade
07/28/2010 8:13 PM
Well, yes, but.........polyester resin is much easier to work with and less expensive.
True acrylic resins require accurate mixing and more sophisticated processing equipment.
Do you have any experience molding thermoset plastics?
07/28/2010 8:23 PM
no. I am truly a novice. I had an idea for a craft, but am wondering how to make it work. Any ideas would be helpful. Thanks.
07/28/2010 8:42 PM
Acrylic is not for beginners.
First, watch this:
Casting polyester resin in silicon mold
This will lead to others. I'm sure there are forums on casting with polyester.
Visit the websites .
Good luck.
And, sorry I can't resist. It's the same in south FL, too.
Re: Clear Acrylic Lampshade
07/28/2010 9:15 PM
Heat resistance would be my primary concern along with ultraviolet radiation. If your light source is cool and doesn't emit UV, you should be ok. An LED light source might work.
Mr.Ron from South Ms.
07/29/2010 5:45 AM
This might be worth looking into, http://www.shopmaninc.com/kk121.html. I think I've seen small kits at Home Depot.
07/29/2010 5:20 PM
thanks for your help guys.
Register to Reply 6 comments
kramarat (1); lyn (2); Rednek000 (2); ronseto (1)
