Previous in Forum: Pressure Test   Next in Forum: Dust Product Cleaning
8 comments
Good Answers: 11
"Ultrasonic Impact Technology" another name for "Vibratory Stress Relieving"?
07/29/2010 2:58 AM
I have noticed a seminar on "Ultrasonic Impact Technology (UIT)" presented by Applied Ultrasonics USA being promoted in Sydney Australia and am concerned that it is another name for "Vibratory Stress Relieving". I saw "Vibratory Stress Relieving" used instead of thermal stress relieving on several new large power station Coal Handling Plant steel fabrications with catastrophic results in the mid 80's in Sydney e.g. ~700mm deep universal beams cracked right through. Does anyone know whether these processes are related or otherwise?
Background information
http://en.wikipedia.org/wiki/Ultrasonic_impact_treatment
says this:
Ultrasonic impact treatment (UIT) is a method of metal improvement that utilizes ultrasonic energy. The physical characteristics: controlled residual compressive stress, grain refinement and grain size reduction. Low and high cycle fatigue are enhanced and have been documented to provide increases up to ten times greater than non-UIT specimens.
and leads to documents from Applied Ultrasonics
http://en.wikipedia.org/wiki/Vibratory_stress_relief
says this:
Vibratory Stress Relief, often abbreviated VSR, is a non-thermal stress relief method used by the metal working industry to enhance the dimensional stability and mechanical integrity of castings, forgings, and welded components, chiefly for two categories of these metal workpieces:
· Precision components, which are machined or aligned to tight dimensional or geometric tolerances. Examples include machine tool bases or columns, components of paper mill, mining equipment, or other large-scale processing machinery, and centrifuge rotors.
· Heavily loaded metal workpieces, which are components designed and built with the ability to withstand heavy loads. Examples include lifting yokes, clamshell buckets, crane bases, vibratory screening system frames, ingot processing, and rolling mill equipment.
Good Answers: 109
Re: "Ultrasonic Impact Technology" another name for "Vibratory Stress Relieving"?
07/30/2010 3:01 AM
Hi,
to my understanding there is a fundamental difference although both procedures are aimed at stress relief:
ultrasonic (or sonic) impacts act as in shot peening: locally compressing the surface, compression is transforming any stress near the surface into compression.
Weight, velocity, energy per pulse and form of impactor has to be chosen carefully to avoid damage. (you don't like a mechanical woodpecker work on your surface).
Surface coverage must be total in and near critical areas (the highly stressed zones).
Vibratory stress relief acts with mechanical oscillations that are amplified by resonances, so there has to be a suspension where and how to attach the part with low damping, a search for resonances by coupling the exciters to different points of the structure and a scan (sweep) in frequency to localise the resonances and the related dampings: give the structure a lot of stress but not as much as will cause damage. (fatigue stress well to be avoided) If the cyclic sinusoidal stressing is done with first rising and the decaying amplitude the stress in the cyclically stressed areas is relieved if the sum of internal stress plus cyclic stress was above the yield limit.
All this is difficult to optimise - same with thermal stress relief.
RHABE
Good Answers: 11
08/08/2010 6:55 PM
Thanks Rhabe,
Thanks for your advice (which gets my GA vote).
Regards
Malcolm
Good Answers: 74
07/30/2010 10:27 PM
Very interesting subject. I'll be following this, Ky.
The Twain Has Met
08/01/2010 11:34 PM
Spam removed:
This post was edited because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
mutual benefits!
Netherlands - Member - New Member
08/07/2010 4:37 AM
Dear Mr. Stephen,
I worked a few years as a consultant in Europe for the Ultrasonic Impact Technology so I know something about this issue.
The only comparisment between UIT and Vibration Stress Relieving (VSR) is that both technlogogies work with high frequency vibrations. When looking at VSR you need to bring the complete construction into resonances and the parameters completely depend on the structures dimensions and it is applied after te structure is finished. UIT however is only applied on small areas such as weld and HAZ and when it is used for stress relieving it should be applied on every single weld layer in order to reach max. stress relieving, this because the ultrasonic effect is only working up to max. 12 mm depth (depends on the materials properties). Here also you need to adapt the parameter according to the material to treat but it is less complex as for VSR.
If you want to use UIT for stress relieving issues than you need to be aware of the fact that this is not general accepted in regulations as a method for stress relieving and therefore you will need an approval in front from a customer or any inolved notified body. In some cases (when it concerns repairs) you can easy get such approval especially when normal PWHT is not possible for some reason.
If you have investigate the application areas of UIT you will see that it's mostly used for increasing fatigue strength of welded structures such as bridges and train boogies or other dynamic loaded structures.
So if you need some more detailed information you can always asked for.
Best Regards,
Herman Pieper
Best Regards, Herman Pieper
Good Answers: 11
08/08/2010 6:56 PM
Thanks Herman,
Regards
Malcolm
12/21/2011 7:07 AM
dear Herman,
could you please provide the details of known service providers of UIT. We have a situation where in local PWHT is not practical on the small repair weld of a process equipment & hence we would like to suggest UIT by expert service provider.
regards
gireesh
12/21/2011 11:43 AM
Dear Gireesh,
I don't know where you are located but as far as I know UIT these days is only presented by Applied Ultrasonics Alabama - USA. In Europe we stopped providing this service and also in Australia they stopped providing UIT services. In Europe we find a cheaper and more reliable way to executed similar treatment. This system is called Pneumatic Impact Treatment, it's not exactly the same but we also use this for stress relieve applications. Working can be proven by way of distortion test with and without PIT treatment. There will be about 30 - 40% less distortion when applying PIT on each single weld run. Unfortunately this technology is only available in Europe.
Register to Reply 8 comments
ATC (1); gireeshh (1); hpi001 (2); ky (1); Malcolm Stephen (2); RHABE (1)
