Previous in Forum: Realkalization of Concrete Structures?   Next in Forum: Windmill ?
Valve Terminology
07/29/2010 9:35 AM
Hi friends,
Can anyone help me with an explanation about valves?
What is the difference between pressure regulator, reducing valve and pressure regulating valve?
Thanks
Re: Valve Terminology
07/29/2010 10:28 AM
These terms are largely synomymous. A pressure regulator can be configured to control the upstream pressure, the downstream pressure, or the difference between the two pressures. "Reducing valve" more commonly refers to a downstream pressure regulator.
United Kingdom - Member -
07/30/2010 2:10 AM
You are right of course, but I would add that a valve that controls upstream pressure is usually called a back-pressure valve and all three terms distinguish this type of valve from a control valve.
Drew
Good Answers: 29
07/29/2010 11:02 AM
And a PRV or Pressure Regulating Valve accepts a variable input, below it's max design pressure, and delivers a regulated constant set output.
07/30/2010 3:14 AM
All responses good. My two cent's.....This is also the point when these various types of valves design should be noted, because there is generally a seat/trim design that relates to the valves function, such as where the process flow enters the valve body - under the seat or on top of the seat, various trim designs,or which side of a diaphragm flow is sensed, etc.
Canada - Member - I am from Canada Eh' Engineering Fields - Mechanical Engineering - Condition Monitoring, Advanced Diagnostics and Engineering Services Engineering Fields - Aerospace Engineering - Aviation Aftermarket Services for Honeywell Aerospace
07/30/2010 4:47 AM
A pressure regulating valve modulates the pressure to a fixed value as does a pressure regulator.
A reducing valve put simply would be like taking your hose to wash your car, turning the water on and cracking the nozzle to a trickle on the end creating a "reducing valve"
By doing this you have effectivley "reduced" the pressure but still have flow.
Its early (0530) here and I have had no coffee yet, my apologies if this doesn't make complete sense, it does to me...LOL
Better to have loved and lost than spend the rest of your life with a psycho.
ad016 (1); RDGRNR (1); The Green Bastard (1); Tornado (1); wailinharp (1)
