Previous in Forum: Diaphragm Pressure Switch   Next in Forum: FCV and PCV Valve Differences
23 comments
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Accurate Low Speed Measuring
07/29/2010 6:55 PM
One of my customers has given my company an interesting project this year. It's a rather simple, create a multiple station test loop to do destructive testing by inducing impact damage.
The mechanical engineers have designed a sled that is accelerated up to a given speed. Once at speed the sled is released from the drive chain and allowed to free-wheel until impact.
I am measuring the free-wheeling speed using two proximity switches that are spaced X distance apart (17.6 inches for now but may be as ar apart as 24 inches in the future) and connected to a PLC. From there I am timing how long it takes the sled to travel between the sensor and then calculate the speed with the two known values. Simple and straight forward and after running over a thousand test cycles the calculated speed varies by ±0.07 MPH which is mainly a result of the PLC scan time.
What my customer and I are looking for now is a secondary means of verifing the sled free-wheeling speed independent of the PLC. The measuring unit must be non-contacting and have a very rapid response time (10mS or less), accuracy should be 2% of reading or better. And it should also be low in cost.
I have looked at the Polytec "Laser Surface Velocimeter LSV-1000" which has a sticker price of around $7,800. It does what I need but the cost is rather high. Assistance in finding other means of verifing the sled speed would be appreciated.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: Accurate low speed measuring
07/29/2010 7:13 PM
just a good old fashioned radar gun is not good enough?
Give me enough duct tape and I can fix anything!
08/07/2010 2:56 PM
The typical radar gun even those used for sports at best will measure speeds down to 6 mph, less than that they wont work plus their error is around ± 1 mph.
I did fail to mention that the speeds I am working with range between 1-8 mph.
Good Answers: 143
07/29/2010 7:27 PM
You should be able to put together an ultrasound unit for about $200. Or, to be really creative, look at Sensors (used to be magazine, now website)
http://www.sensorsmag.com/content/search?keywords=velocity
07/29/2010 7:41 PM
If the measurement technique is not at issue, you could just repeat the configuration of 2 sensors + PLC, using sensors (through-beam or retro-reflective optos?) from a different manufacturer, and a simple logic module (Moeller Easy, Siemens LOGO!, Crouzet Millennium etc) with a built-in display.
Use as big a separation between the sensors as possible/practical.
08/07/2010 3:18 PM
"Use as big a separation between the sensors as possible/practical."
I would love to have at least 35 inches or more for calculating the speed but unfortunately the sled along with the rest of the system has to fit in a building that has already been built so the available footprint is smaller that any of us would like. To reach our top sled speed of 8 mph most of the available sled travel is taken up just accelerating the sled to speed which leaves 24 inches at best to measure the the final sled speed. The next thing some may suggest is use a larger motor to accelerate the sled faster but the mass of the motor becomes an issue when trying to stop the motor, the drive chains and pusher blocks.
As for using a second dedicated PLC and a different set of sensors to repeat the measurement, it is a very good idea, one which I may need to do to keep costs down. The only thing is it will require "Operators" to be very accurate about setting the spacing of the sensors if they move the "Test Unit" from sled to sled. I would first llike to find a method/instrument that is plug and play as much as possible.
08/07/2010 6:58 PM
For sensor spacing - a fixture (2" x ¼" (50mm x 6mm) ally bar or whatever with the sensors mounted thereon) should eliminate errors in test unit installation.
Re: Accurate Low Speed Measuring
07/29/2010 10:10 PM
If you have access to a digital storage scope, you might set up two photocells and two laser pointers spaced an appropriate distance apart (1 ft, or...?) so that the laser beams cross the sled's track. The photocell signals are fed into 2 channels of the o'scope. As the sled breaks the beams, the differential loss of signals from the two photocells can be read from the scope trace as time. The distance and time will of course give you the speed. You might need the services of an EE if the photocell signals need to be amplified, but that could be kludged fairly easily, I think.
Good Answers: 213
07/30/2010 11:15 PM
GA Usbport- the o'scope will give you very accurate data that does not require any sort of time delay for digitizing the signal. I should think there would be no need to amplify the signal from the photo detectors if one is using a bright enough source light (i.e., a laser). The accuracy of the measurement would depend primarily on how accurately you know the distance between the sensors...
08/07/2010 3:21 PM
Nice idea but not user friendly. The people needing to use it are lucky to have graduated high school......if they even did.
07/29/2010 11:10 PM
Too simple. In the "good old days" use a high speed clock (digital or sweep hand) and videotape (Showing my age) the passage of the sled.
Review of the recording will provide you with an accurate transition time and then it's a matter of distance/time to get your velocity.
Absolutely non contact, absolutely repeatable. Only dependant on your ability to read the clock.
In the modern world, digital cameras have inbuilt clocks that can be displayed in the recorded signal. The camera is then available for other use in the lab.
The drawback is that it doesn't directly give you a "speed" that can be electronically interrogated but since this seems to be used to proove your current set-up it might be adequate.
08/07/2010 3:26 PM
Using a camera is a possibility to follow. The customer already is using vision systems as part of their inspection section so they should be able to configure a camera for speed measurement. I will have to research the cost of this option. It just might be a cost effective option.
07/30/2010 3:10 AM
You want a second means to double the chance of it going wrong?
The big question is WHY?
There are a myriad of simple solutions, but it really depends what you ACTUALLY need.
You could simply duplicate the existing system.
Or...
It is very simple to build a circuit.
The first sensor triggers two timers...
The second sensor must be triggered after the first timer has timed out and before the second has timed out.
It's a basic bit of electronics and logic.
Failure to trigger the second sensor in the correct time can sound an alarm illuminate a big flashing light, unleash a spring loaded boxing glove and automatically open a tin of Tuna for any cats in the vicinty.
The circuit can be reset by a short delay after the second sensor or by umpteen different methods.
It doesn't even need a microcontroller.
A good electronics hobbyist (or a cat a squirrel or maybe a sack of Gophers?) should be able to do it.
08/07/2010 3:32 PM
Good suggestion, but I know my customer and they would want something a little less fishy, perhaps can chicken instead of tuna.
Good Answers: 119
07/31/2010 2:46 AM
Can you use a high speed video capture system to verify velocity?
In many impact studies, HS video provides important dynamic information that may be lost by only doing a postmortem analysis. If a new camera is too expensive for you to purchase, demo cameras and rentals are usually available at significantly lower prices.
07/31/2010 12:35 PM
You can use an LVT (Linear Velocity Transducer). See this URL:
http://www.transtekinc.com/products/linear-velocity-transducers.html
You may have to mount a magnet on the sled.
07/31/2010 5:30 PM
Bit tricky to use these things in this application. If you follow the link you supplied as far as the data sheet (LVT wiring), you may notice that the (supplied) magnet has to be inside the measuring coil.
08/08/2010 11:25 AM
Nice idea but it requires physical contact and is limitted to 24 inches of usable travel, my sled as more travel than that. I would aslo be concered with shock damage since my sled will be slamming into fairly solid objects and coming to abrupt stops several times during a typical day of testing..
Canada - Member - New Member
Good Answers: 11
07/31/2010 3:20 PM
What is not defined is the sled speed and resolution you seek.
Del's idea of a counter started and stopped by the sled passage between two points.
Calculate the counter's frequency to get proper resolution time/speed and the number of bits for the counter's elapsed time.
Optical triggering is best, beware of industrial sensors which may have internal filtering and added (temperature variable) time constant.
08/07/2010 3:36 PM
I did miss the speed range of the sled, it is 1-8 mph. The accuracy needs to be 2% of reading or better.
08/01/2010 2:23 AM
This whole thing smacks of a 'problem creation exercise' and I'm thoroughly underwhelmed by the response from the OP.
So I'm out.
Good Answers: 11
08/02/2010 9:40 AM
Still, yours is the way to go!!
Cat prevails!!
08/07/2010 2:49 PM
Sorry for the delay in responding, I have been on the road for the past week with less than stellar internet connections.
This is not a school project.
Now that I am back in the office I will follow the links provided and review eveyones suggestions. Thank you to those that have responed so far.
08/07/2010 3:19 PM
These are not accurate at low speeds and require a lot more time to respond than I have available in this sled.
Register to Reply 23 comments
cwarner7_11 (1); farmatt (1); gigaconcept.com (2); JohnDG (3); Just an Engineer (1); mjb1962853 (1); Richard L (9); TVP45 (1); Usbport (1); user-deleted-1105 (2); WoodwardDL (1)
