Previous in Forum: What's Characteristics of Chair Mould   Next in Forum: Can I use EN19 as option for AISI4140?
8 comments
The Work Flow of IML
08/01/2010 8:33 PM
have you heard of IML? If so,what's the work flow of IML?
Re: The Work Flow of IML
08/02/2010 1:24 AM
Ingatestone Motors Limited used to run a van-hire business in the Ingatestone and Shenfield area in Essex, UK. The company is no longer trading.
08/02/2010 9:38 PM
Thanks for your reply, although your answer is not what I want, at least I know that there is a company named "Ingatestone Motors Limited" in Essex, UK, and has stopped running.
The IML here I would like to say is "In Mold Labeling System"
08/03/2010 9:40 AM
Hi Ya,
What's the problem to tell us at the beginning that you want to inytertain us with "In Mold Labeling"? When you answer to that you have a chance to get a response and solution to your problem, I want to say to your problem at "work". Also, you know everything but we don't have a chance to know or understand what you want. Be clear and precise or clarity and precision get good results, Gil.
Good Answers: 101
08/02/2010 10:19 AM
IML:- I Make Love.
Work flow: I presume you mean process flow. Well, I'd love to tell you, but the site administrators will automatically censor me for it.
08/02/2010 1:52 PM
IML? Had to Wiki it.
There is one hit on Wiki for IML. I had no idea!
Regarding 'work flow of IML', DVader1000 has stated the correct answer.
Good Answers: 204
08/03/2010 12:37 AM
Perhaps you mean UML?
Good Answers: 54
08/03/2010 3:43 AM
Ah, in that case the work flow model would be - Create vague specification of requirements, start coding, continue to adjust program until it does approximately what the customer wants, Revise specification, Fully document UML.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 15
08/03/2010 6:39 AM
IML,
Your question got some deserved answers for its vagueness as you knew that it is an injection molding or compression molding specific question.
Be more definitive with the question and people will treat you with respect.
As to the question. There are many companies that supply labeling systems for IML. Most are automatic reel to reel systems that are extremely expensive but will register the decal or label perfectly in the cavity every time. At 2-5+ cents per label it can be an expensive way to go. There are also hand loaded labels or decals and the tend to be 5-8 cents each + the interrupted cycle of the molding machine----may suit for short runs but are hard to justify.
Get more specific info from the suppliers of the equipment. Try Alibaba etc.
I like 2 tinker-no, really!
Register to Reply 8 comments
2tinker (1); Anonymous Poster (1); chrisg288 (1); Doorman (1); DVader1000 (1); ffej (1); PWSlack (1); sinosiya (1)
