Previous in Forum: Big 5"x 7" Photo Enlarger ( DIY Project)   Next in Forum: Proximity Switches
11 comments
Flow Meter for Viscous Emulsion
08/02/2010 9:28 AM
Hello Friends,
I am looking for a flow meter for an emulsion metering.
The desired specs are:
Liquid type: Neat polymer emulsion.
Viscosity:- 500-1500cps
Sp. Gravity:-0.948
Density:- 1.04 to 1.07 g/ml
Flow Measurement Range:- 0.5LPH to 4 LPH
Nominal pressure :- 7bar
Line Size:- 8mm
Fluid contact part SS316
Remote transmitter 10meter cable
What sort of flow meter would be giving the accurate measure?
We tried Oval Cup Gear type from Great Plains Industries but failed to show any reading.
Thank you in advance!!
Regards
Sharad
I want it to be delivered in India
Pathfinder Tags: Flow meters
Re: Flow meter for viscous emulsion
08/02/2010 9:42 AM
  • Maintain zero differential pressure across a gear pump at a known speed?
  • Coriolis mass flowmeter?
08/02/2010 10:08 AM
Hello PW Slack,
Differential pressure is 7 bar.
Thanks
08/02/2010 10:43 AM
  • Maintain zero differential pressure across a gear pump at a known speed? The principle is that if there is no differential pressure across a gear pump then their is no slip at the pump. Then, the speed of the pump can be used to work out the flowrate given the displacement.
Good Answers: 19
Re: Flow Meter for Viscous Emulsion
08/02/2010 12:08 PM
technology: thermal dispersion.
claimed flow rates as low as 10 cc/day . . .
http://www.coleparmer.com/catalog/product_view.asp?sku=3290001
Good Answers: 25
08/02/2010 12:31 PM
Sp. Gravity:-0.948
I don't think the numbers above can be correct unless I am missing something.
Troy
08/03/2010 9:09 AM
+1 for Coriolis
Not the cheapest meter but a good way to get very good accuracies at low flow rates.
The issue is your viscosity. If the actual DYNAMIC Viscosity really is 1500 cP then it may be tough to get your flow though a small enough sensor to get good accuracy at the low flow with your available line pressure. The lower the viscosity the smaller pipe you can use and the better acc you will have.
You will need a sensor tube about 0.10 - 0.16 inch in diameter.
Good Suppliers are:
Siemens- http://www.automation.siemens.com/w1/automation-technology-coriolis-18645.htm
Micro Motion - http://www2.emersonprocess.com/en-us/brands/micromotion/Pages/coriolis-flow-density-measurement.aspx
E+H - http://www.us.endress.com/
Cheers,
Eric
Good Answers: 176
08/03/2010 2:43 PM
The Siemens coriolis meter used for low flow probably will not work. The tube diameter is only 1.5mm, (0.06"), typically needed for low flow rates like this.
But the pressure drop is excessive for the range of viscosities; as you can see from the chart below. The user has only 7 bar pressure to work with.
0.5Kg/hr at 500cSt takes 3bar pressure, which might be OK, but the upper flow rate of 4Kg/hr at 500cSt takes 12+ bar.
The pressure drop situation at 1,000 cSt is untenable.
08/03/2010 3:43 PM
The 1.5mm Siemens low flow Coriolis sensor was not suggested for the very reason you mentioned, delta P is insufficient for these viscosities.
The 3mm (0.10") and 4mm (0.16") sensors tubes were suggested as a viable solution providing acceptable accuracies and reasionable delta P values. Additionally as the viscosity as stated is most likly a static viscosity and not dynamic the actual delta P will be lower then the worst case calculations once the flow starts moving.
08/03/2010 8:37 PM
Smith Meter Erie PA makes a flow meter for viscous emulsions.
08/04/2010 10:32 PM
What type flow is it, is it batch or continuous? If batch you could use load cells on supply tank or receiver tank. If it is continuous you may try a Doppler type.
Raz
Good Answers: 48
08/11/2010 12:09 PM
A few questions:
1. "What sort of flow meter would be giving the accurate measure?" What sort of accuracy do you want?
2. What is actually conveying the fluid? (Pump, gas pressure, gravity?)
3. You mention 7 bar nominal pressure (system pressure?), then 7 bar differential pressure. Is this across the pump, the flowmeter or what?
PWSlack's suggestion to use a gear pump is very good, especially with the range of flowrate, viscosity and pressure involved here.
Register to Reply 11 comments
Bud (1); Ducdude (2); Holzfeller (1); Iris (1); PWSlack (2); Raz (1); roadapple (1); sharadmandale (1); Troy36 (1)
You might be interested in: Gas Flow Meters, Flow Meters, Paddlewheel Flow Meters
