Anyone with a design based on wood frame rather than steel? I could live with a less-than-perfect focusing system so long as focus is reasonably possible. Living in Alaska, I can't ship such a big unit up here. My negatives are 6cm x 17cm(that's 7 inches long). A 4x5 enlarger won't do it. Basics: the enlarger consists of a proper and quite brilliant light source, a condensing element that ensures the light is completely evenly spread over the negative (very important), a small bellows above the negative carrier, a negative carrier, a bellows below the negative (probably from an old 5x7 camera will work) and a lens for focussing onto the print paper below. Now can you advise me from there....????
