Previous in Forum: 2003 Chevy Cavalier Won't Start   Next in Forum: Fiat Uylsse Engine Problem
16 comments
Good Answers: 76
Tree Sap Removal from Automobile
08/02/2010 1:51 PM
Greetings fellow CR4'ers.
So, I find myself dealing with an issue for the first time; tree sap on my car. Today marks the conclusion of two weekends of trying various entry-level remedies… (e.g. washing with very hot water and elbow grease, different kinds of soaps, etc) all to no avail.
I now am beginning the next phase of sap remediation. Concurrent with this post, I am starting to log all the places I've parked my car over the past month and then will research those areas in an attempt to identify the types of trees and, as a result, the potential type of sap.
I will also start my internet searching tonight. But when it comes to putting anything but soap, water, and car wax on my car's exterior, I am quite hesitant. And since anyone can post on the internet, I am going to hold all information garnered there as suspect.
I am hoping that this forum might provide some sound advice. Seeing as how we have a plethora of automobile enthusiasts here who are also very technically competent in many scientific fields, there might be someone that has had to deal with this issue and found a good method to remove the sticky parasite from a horseless-carriage without damaging it's finish.
Through my efforts to remove it to-date, I have only succeeded at spreading it around and thinning it out. As it has since picked up foreign particulate; a mat finish is developing and… well… looks like crap.
The car in question is a 2010 Ford Fusion, Tuxedo Black in color. I presume that it has a factory-applied clear coat of which I have not researched yet so I am unfamiliar with what it is, how it's applied, and its compatibility to various type of things that could be applied to remove the sap.
Your input would be graciously appreciated.
JavaHead
Good Answers: 119
Re: Tree Sap Removal from Automobile
08/02/2010 2:07 PM
I seek out parking spaces that deposit the most tree sap. After 12 years and 180000 miles of hard driving in hot summers and salty cold winters, the only rust-free spots on my car (98 Ford Escort) are the ones covered by the thickest accumulations of tree sap.
Since turpentine is derived from tree sap, it should be a good sap removal solvent. BE CAREFUL since it might not be good to your clear-coat. Good luck!
08/02/2010 2:12 PM
Rubbing alcohol removes pine sap nicely. Don't know what it will do to your clear coat though.
08/02/2010 7:50 PM
When I take my car in to have it detailed, they have a product that removes sap and tar and other gunky stuff. You might try asking your local car wash what they use.
08/03/2010 5:56 AM
I've had good luck with alcohol with no adverse effects on my paint (or clearcoat).
It even worked better then a commercially available Bug & Tar remover that was supposed to work on sap as well.
Shawn
08/02/2010 11:17 PM
Try DMSO, dimethyl sulfoxide. But wear gloves.
08/02/2010 11:19 PM
WD-40.
08/03/2010 8:42 PM
WD-40 is one of the best all around lubricants and an amazing solvent. Wish I had invented this product or Velcro. WD-40 has many uses besides lubrication.
Good Answers: 56
08/03/2010 5:43 AM
Place a paper towel on it. Soak it in kerosene or #2 fuel oil for 24 hours. Wipe it off.
Won't hurt paint or gel coat.
Same technique for bird droppings.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Good Answers: 19
08/03/2010 6:07 AM
Liquid laundry detergent similar to "ALL" work well to get the stuff off me , I would think it would work on a car as well.
it's worth a try before ruining your paint.
how about TSP (Tri Sodium Phosphate)? It works on houses.
There's a theory stating if anybody discovers exactly what the Universe is for & why it is here, it will instantly disappear & be replaced by something even more bizarre & inexplicable. There's another theory stating this has already happened.D Adams
08/03/2010 8:12 AM
There's a product called Goo Gone that works very well on adhesives from decals and labels and is also quite gentle on the finish. I've used it many times and it always works. WD-40 is another good solvent for tree sap and tar.
08/03/2010 9:24 AM
I use a product from walmart called 'Super Clean'.It does well on about any oily based substance, and does not seem to affect my clear coat. It should be deluded with water on first try or used on a out of the way place due to the different paints and coats..I use it on my 76 Caddy and works well...
Jim
08/03/2010 2:38 PM
Had to give the WD-40 a GA. Does work with small and thin sap.
A soft cloth damped with kerosene works well for me. Initially sop the sap (sounds funny) and let set for a little while. Remove as much as seems easy to come off, but don't get aggressive. Repeat as necessary.
However, when one allows the sap to harden, it becomes more difficult. If in a high glob, I usually begin with using a razor scraper to get the top part off, and of course carefull not mar the paint. I've also found that if the sap is ignored and not removed for some time it will damage the paint/clearcoat.
Good luck!
08/03/2010 4:41 PM
Try using a detailer's clay bar & lubricant spray (Mothers, Meguiars, etc...). The clay provides a shearing action for contaminants embedded in and/or stuck on the surface.
Good Answers: 97
08/04/2010 6:11 AM
I use undiluted Murphy's oil soap.
here is a good list:
http://www.gardeningknowhow.com/trees-shrubs/how-to-remove-tree-sap.htm
Good Answers: 76
08/04/2010 7:46 AM
Thank you all for the replies…
On my end, I scoured the internet, visited two local body shops, and called a prominent classic car detailer… Where the internet findings resulted in solutions spanning the entire spectrum of plausible, and not so plausible, solutions… the body shop resulted more towards 'bring it in and for a fee, we'll get it off for you'… and the classic car detailer lead me to a recommended solution, along with a back-up plan.
Their recommended solution, was in-line with many suggestions found here… WD-40 and depending on the age of the vehicle, a claying. Since my vehicle is pretty new, claying is not needed at this time and the WD-40 worked perfectly.
For CR4's future reference, their pack-up plan was to point me to a web-site where I could find additional options if the WD-40 didn't work… They said the site is not just a marketing tool for various products, but also contains some very helpful 'how to' type instructions for the do-it-yourself car-care types.
I perused the site for about an hour and found all kinds of useful advice and instructional information, just have to look past the marketing slang as you read. But, I did notice that they just don't market a single manufacture's product, and the ones they do are on the 'more reputable' side. So a useful tool in both regards, I suppose.
But, the WD-40 worked for me… so GA guest! It's a shame you don't register.
JavaHead
08/04/2010 8:32 PM
Try mayonaise. I have used it to remove sap from my skin and shoes.
Register to Reply 16 comments
Altair (1); Anonymous Poster (4); Bill ML (1); bwire (1); ddphillips (1); Geode Hunter (1); JavaHead (1); jtd405 (1); Laughing Jaguar (1); mjb1962853 (1); rcapper (1); roadapple (1); Shawn33 (1)
You might be interested in: Planters, Wellhead Equipment, Automotive Services
