I live in the UK and own a 2 Litre JTD Fiat that was made in 2000 / 2001.
It has 16 valves with single cam drive and exhaust recirculation. it is the RHW Diesal engine.
The problem that i have is that the fuel injectors do not seem to work?. The engine cranks over and fuel is being burnt but dose not start. If you spray Ethanol into the air intake it will start.
The Alarm system has been reset.
the fuel injectors are about a foot long and also bolt down the camsharft cover. and beeing at the back of the engine you will have to drop the engine out to remove them.But as they go through the aluminium cylinder head. they corrode in place as they go through the water jacket of the head.
is there a pressure sensor inside the injector.
Is there any way of testing that they work whilst still in the engine.
The glow plugs are also at the back of the engine and cannot be removed without dropping the engine.
A compression test cannot be carried out.
We have 10 volts on the glow plugs. 2.6 - 6.6 volts constant on the injectors plus an extra voltage of 3.6 - 6.6 when firing.
continuity on the solinoids. 1 cylinder = .6 ohms, 2 cylinder = .9 ohms, 3 cylinder = .7 ohms 4 cylinder = .7 ohms.
Dose anyone have any information on these injectors as to how to test them or how many watts they use.
This engine is also used in Fords and Renults. But the ECU diagnostics are different.
Thank you for your help.
