Previous in Forum: Where Can I Find a Red Lion CL 20 Model 200010   Next in Forum: Vibration Producing Device for Testing
Float Switch for Chemical Application
08/03/2010 6:57 PM
Does anyone know of a float switch that will work in sulfuric and caustic soda application?
Please send part#, mfg. A link would be helpful.
Greatly Appreciated.
Re: Float Switch for chemical application
08/03/2010 7:06 PM
Ryan Herco or Harrington or any switch supplier can help you.
Re: Float Switch for Chemical Application
08/03/2010 8:07 PM
I know my father spoke good of this company SMD Fluid Switch as it was local to BYK Chemie where he worked ... hope it helps you! They might be able to supply you with what you need. One switch for both sulfuric and caustic soda. The SG for Sodium Hydroxide (caustic soda) is at 1.22 and Sulphuric Acid 20% is at 1.14. I found this info from their site. http://www.fluidswitch.com
Specific Gravity (SG) is the ratio of object's density to that of water. Since water has a specific gravity of 1 at sea level, liquids and substances with a specific gravity lower than 1 will float in water. Therefore it is improtant to select the proper float switch and float for your application. When using oils, Buna or NBR floats are best. These floats have a low specific gravity, around .5, and will float well in in most petroleum products ranging from .7 to .86 SG. For example a float switch with a specific gravity of .8 will float well in water but will sink in alcohol which is around .72 SG.
Below is a table liquids for reference.
Liquid
SG @ 60ºF / 15.6ºC
Liquid
SG @ 60ºF / 15.6ºC
Tap Water (Reference)1.0Machine Lubricants.88 - .94
Automotive Oil.88 - .94Milk1.02 - 1.05
Beer1.01Peanut Oil.92
Carbon Tetrachloride CCl41.59Propylene Glycol1.038
Corn Oil.924Sodium Chloride 5%1.037
Crude Oil.79 - .86Sodium Hydroxide (caustic soda)1.22
Diesel Fuel Oils 20.82 - .95Sulphuric Acid 95%1.839
Ethylene Glycol1.125Sulphuric Acid 20%1.14
Gasoline.68 - .74Triethylene Glycol1.125
Kerosene.78 - .82Turpentine.86 - .87
Jet Fuel (av).62Water, Fresh1.0
Lard Oil.91 - .93Water, Sea1.03
For more information on SG, please visit the following:
Material Selection and Chemical Resistance Information
Choosing the correct switch materials can often mean the difference between years of dependable service and equipment failure. Materials that work well in oils or petroleum products may not be the best for common detergents or hot water.
  • Stainless Steel - Ideal for high temperatures, high pressures and corrosive environments such as food equipment, industrial tanks or durable general use.
  • Brass, Nylon or PBT stems with Buna-N Float - Good for petroleum products, oils and wastewaters. Buna-N floats have superior buoyancy and can be configured for oil-water interface detection.
  • General Use Plastics - Polypropylene, PVC and Polycarbonate good to 105 degrees Good choice for general use, acids or food applications. Can be designed economically or custom molded with additional features for OEM applications.
Material Chemical Resistance Table
http://www.tank-depot.com/engineerdata/chemicalres.pdf
Cross reference the following sites for added material selection information:
http://www.enineeringtoolbox.com/24_336.html
CR4 Admin – E-mail Address Removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
08/03/2010 8:29 PM
Well written. Greatly appreciated.
08/03/2010 9:07 PM
Thank you but I did not write it... I simply organized it to the subject at hand. You can access that same information from their site. Good Luck!
08/04/2010 2:53 AM
Try KSR Kuebler (usual disclaimer).
08/05/2010 12:44 AM
Dear Magnetrol can help you in this regard.
http://literature.magnetrol.com/1/41-178.pdf
Please find this link
08/05/2010 8:06 AM
What concentrations and temperatures are your solutions?
The MultiTrode Probe is a very reliable maintenance-free alternative to ball floats.
http://www.multitrode.com/liquid-level-probe/compatible-chemicals.html
Register to Reply 7 comments
CNCNuckingfuts (2); Critcho (1); lyn (1); PWSlack (1); rabat (1); raees (1)
You might be interested in: Switch Boots, Audio Switch Matrices
