Previous in Forum: Spring Washer   Next in Forum: Pump Motor Coupling Alignmnet
Air Line Losses in Pipe and Flexible Metallic Hoses
08/05/2010 3:10 PM
Dear All,can any body tell me that what is the difference between frictional pressure loss of air in a cast iron pipe and a flexible metallic hose of same dia and length.
plus if there is difference then on which factors this depends like the longitudinal cross section of hose etc.
thanks,
regards,
hasnain
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Re: Air Line Losses in Pipe and Flexible Metallic Hoses
08/05/2010 5:37 PM
Frictional loss is a factor of diameter and length. Of course, material properties have an effect, but it depends on what the internal diameter and length of your hose is in order to consider them.
It is better to fail in originality than to succeed in imitation.
08/05/2010 11:48 PM
Not much. The higher the velocity of the air, the higher the loss.
Ask Mr. Reynolds.
08/06/2010 3:22 AM
How about the Darcy-Weisbach generalised equation for flow in round conduits?
Economist (1); lyn (1); PWSlack (1)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
