Previous in Forum: Air Line Losses in Pipe and Flexible Metallic Hoses   Next in Forum: High Concentration Slurry System
Pump Motor Coupling Alignmnet
08/05/2010 11:53 PM
HI All
Please let me if there is any standard which govern the Pump Motor coupling alignmnet lik HIS or API610, ANSI , desiranle
Link to material is highly deserible.
Regards,
Mahipal
Good Answers: 67
Re: Pump Motor Coupling Alignmnet
08/06/2010 2:49 AM
I am not aware whether any standard available. Generally the guidelines from OEM is followed. For bigger equipments in some cases, OEM's recommend 'cold misalignment' (to take care of thermal expantion) so that machine will get aligned in hot condition while running. Howevere, if OEM recommendation is not available following guideline for coupling alignment tolerances can be used:
- Axial misalignment for flexible couplings : 0.02/100 mm
- Axial misalignment for solid couplings : 0.01/100 mm
- Radial misalignment : 0.03 mm
-Concentricity (dial indicator on periphery of coupling): +/- 0.05 mm
(0.10 mm total indicator run out)
08/07/2010 11:33 AM
Mahipal
If for some reason you do not have a dial indicator...use a rule + feeler gauges
Use the rule across the coupling flanges and check gap with feelers - tap to align..
Reply Score 1 for Off Topic
10/15/2010 8:13 AM
Dear friends,
I wish to know about the Pump motor alignment general tolearances,
pl let me know if any one having the details about the same.
Regards,
Murtaza H Shakir
murtuz_engg@rediffmail.com
Good Answers: 67
10/18/2010 1:52 AM
Following general norm can be followed in absence of OEM recommendations:
- Axial (for fexible couplings) : 0.02/100 mm
- Axial (for rigid couplings) : 0.02/100 mm
- Radial : 0.03 mm
- Concentricity : +/- 0.05 mm
You might be interested in: Motor Test Equipment, Motor Repair Services
