I have been in discussion with RCE another CR4er about mixing different aquifers encountered in the same well. That discussion has led to creating this discussion about testing water from wells. Primarily the interest is in private wells in rural areas that fall out of regulation with regard to testing.
I would suggest it is imperative to have credible analysis preformed by accredited labs. There are a lot of door to door salespeople selling water treatment and I have seen their magic tricks to sell equipment and do not have much faith in their abilities to test or interpret results. The testing seems designed to sell water softeners but I will not paint all these salespeople with the same brush. A recent article in the Canadian Medical Journal raised the alarm about the lack of testing of private wells. I can attest to the problems after sampling water from aboriginal wells in Ontario and finding lead elevated to high levels and over the drinking water quality criteria for public water supplies. Our sample size was over 300 and our adverse lead was found in 34%. Almost all of it could be attributed to poor well maintenance and well biofouling. De-fouling of the wells removed all lead issues and a program of control was established.
The question; if you had a private well newly drilled or already existing and you thought about testing it, what would you test and at what frequency (annual, 10 year, seasonal, after heavy rains, during droughts, etc)? Some suggestions are for bacteria such as the indicator groups but there is a whole host of things most homeowners think is not a problem; Barium, arsenic, nitrates, uranium ion, lead, and a plethora of organic chemistry. Bear in mind that the onus is on the well owner (unlike a regulated water system) to pay and have these results collected and interpreted. Lab fees are somewhat expensive especially if you are asking for isotopes. I am now retired but did have a small set of analysis we did as a routine for private rural wells. Our testing was done on untreated water and was designed to place parameters on a redox curve. Interest was also in microbiological as well as chemical testing. It included general major ion balanced to within 5%, heavy metal scan, physical parameters (pH, conductivity, TDS, turbidity, color, UV transmission) Ionic balance, Langlier Index at various temperatures). The package cost a homeowner $500.00 CDN (that was five years ago) and included collection, lab fees, and interpretation. This was a break even level of costing but seemed to reflect what homeowners thought was a reasonable maximum. If we thought other parameters may be an issue we would recommend a more detailed set at higher cost (methane, pesticides, herbicides, radon, radioactive considerations, petroleum products, to name a few). I also suspect some area testing will vary due to industrial and agricultural practices. Questions could also be raised about the samplers and qualifications to interpret the results. Questions could also be raised to mandate testing at times of property transfer for example. Your thoughts and inputs are valuable to what I consider a very misunderstood issue. I own a drilled well and am my own utility operator.
Some sites of interest are World Health Org, Canadian Water Criteria, EPA testing
