Previous in Forum: Filament Winding   Next in Forum: Turbocharger - Rotate Turbine Wheel Using Air Blower
Limestone Filter
08/09/2010 11:43 PM
I need drawing of lime stone filter ,used for re-mineralization plat.I also need its operation document.
Re: Limestone Filter
08/10/2010 5:21 AM
Operation:
  1. Isolate and drain the vessel.
  2. Open it and charge the vessel with limestone.
  3. Close the vessel
  4. Remove the isolation
  5. Monitor pH at the vessel outlet connection. Once it starts to fall, assume the limestone has run out and repeat from 1.
