Previous in Forum: Pressure Switch   Next in Forum: Difference b/w MWP and Calibration Range
Air Flow Control System Trainer
08/10/2010 6:31 AM
We've designed an air flow control system trainer that involves a blower, a damper a pneumatic actuator and PID controller for our project study. For research, we need to compare it to existing designs, can you tell me other designs of an air flow control trainer?
Good Answers: 101
Re: Air Flow Control System Trainer
08/10/2010 9:39 AM
Congratulations! You finally found a project your lecturer approves of. Check out the following link:
http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENSG297&q=air+flow+control+trainer&aq=0&aqi=m1&aql=&oq=air+flow+cotrol+trainer&gs_rfai=
08/13/2010 11:29 PM
thank you, our prof wants us to add more, she wanted to see another feed other than air, so we're trying to think of improving the design.
08/11/2010 12:12 AM
Good
But, your description doesn't tell much about what experiments you can conduct. If you give more details of total set up and the list of experiments, CR4 members can suggest many more things.
(I have experience of more than 12 years in design of trainers for engineering collages)
Register to Reply 3 comments
DVader1000 (1); gsuhas (1); kcb27 (1)
