Previous in Forum: Flow Meter Selection   Next in Forum: Air Flow Control System Trainer
Pressure Switch
08/09/2010 11:41 AM
I have a pressure switch of which set point is 1415psi (as per data sheet). the min / maximum line pressure as follows 1340 psi/1415psi.
Normally we do calibration by fix the setpoint on 1415psi.
but vendor did calibration like this way(all units are taken in psi)
setpoint on off switch differential
290 245 290 45
1000 965 1000 35
1715 1680 1715 35
can anybody tell that did vendor calibrate in the right way /if so then what is the purpose of considering switch differential so high?
thanks
Re: pressure switch
08/09/2010 11:48 AM
The data looks like it is for three switch settings. As none of these comes anywhere near the line setpoint settings, one wonders if this data is for the same piece of equipment?
As far as the differential is concerned, it may well be that the setter has no option on the matter, and this is simply the reading obtained from each switch setting. It is usual for the transition point between one state and the other to differ between rising pressure and falling pressure.
Re: Pressure Switch
08/09/2010 1:16 PM
If the differential (or deadband) is small, the process will have closer control, but the item controlled (compressor, valve, etc.) will cycle on and off more often.
Conversely, if the differential is large, the process will be less tightly controlled, but the equipment will cycle on and off less often.
Thus there is a trade-off. Your choice will depend on what is more important to your process: tight control or fewer starts/stops and less wear on equipment. It also depends on what differential ranges are available for various models of pressure switch.
Re: Pressure Switch
08/09/2010 7:02 PM
Figures look good to me (tho' you didn't say what the datasheet said about hysteresis).
If you need tighter control, get a "better" (lower hysteresis) switch - or consider using an analogue transducer and a PID controller.
Re: Pressure Switch
08/09/2010 11:22 PM
more details about data sheet
service & location for this witch is : sales gas
output action : open on high pressure
pressure element : diaphram
model/manufacturer: zppx-p160 /waaree instruments
calibration looks strange because of so high dead band.
my question is is this the right way of calibration
thanks
Re: Pressure Switch
08/10/2010 5:11 AM
What does the switch manufacturer have to say on the topic?
Re: Pressure Switch
08/11/2010 1:25 AM
Hi,
What the switch manufacture should say is in this website: http://www.atc-inst.com/ , you can check it now!
AMERTEC
Re: Pressure Switch
08/10/2010 5:32 PM
The manufacturer's datasheet states that the differential is fixed (but doesn't specify it). It also states that the repeatability is ±1% and the scale accuracy is ±3%.
The figures you've quoted for the calibration show that the setting is spot-on (the switch cuts off at the set pressure).
A differential of 35psi at your working setpoint of 1415psi is less than 2.5%.
Unless I'm not understanding your question, I don't see any problem. Can you explain more?
Anonymous Poster (2); JohnDG (2); PWSlack (2); Tornado (1)
