Previous in Forum: Spacing Between the Supports in Piping   Next in Forum: Pumps Book
President , Ralph Pope Enterprises, Inc.
08/12/2010 10:14 AM
I am in need of a small torsion Spring with the following specs :Dia.=1.75 to 2.00 in.max no of coils= 3 to4 , Rod or inside dia.= 1 3/8 in. , Deflection angle=180 degrees, wire dia.= 1/8th in. One leg= 3 to 4 in. the other = 1 to 2 in. , The long leg rotates attached to a 18 in Arm. the short leg is Fixed. The required lifting strength is 6 to 8 lbs at the end of the 18 in. Arm. I have tried several combination`s but the coils become distorted , and end up with only 3 to 4 lbs of force. Should i use heavier Wire? or ? . Should the entire Torsion Spring assem. be enclosed to prevent distortion? . I am very limited on space . I would appreciate any suggestions to help solve this problem.My Name is Ralph Pope , Thanking you in advance , Ralph Pope Jr.
Re: President , Ralph Pope Enterprises, Inc.
08/12/2010 10:27 AM
check with McMaster-Carr, they have lots of springs.
Good Answers: 29
08/12/2010 10:43 AM
Quite right! OP- take a look here.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
08/12/2010 12:40 PM
Maybe a coil spring is not an option, there are other types that may fit your needs better.
Try theese guys
http://search.globalspec.com/ProductFinder/FindProducts?query=spring
http://www.spring-makers-resource.net/
Give me enough duct tape and I can fix anything!
Good Answers: 15
08/12/2010 4:11 PM
Lee Spring has a nice website
downhill slide to 112 (damn memor.)
ddk (1); dgibson (1); farmatt (1); RDGRNR (1)
