Previous in Forum: 96 Saturn SL   Next in Forum: Help on Fixing a Lowrey Debut L70.
12 comments
96 Saturn SL
08/12/2010 12:29 PM
When I was driving the rpms would rev up in any gear I shifted to when I stopped there was smoke coming from the driver side. Afterwards I was drIving it and the rpms was still doing the same thing. Then it would not go anywhere. When I stopped I tried to Put it in any gear even reverse and let go of the clutch and it did not die it just stayed running.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: 96 saturn sl
08/12/2010 12:39 PM
You burnt your clutch out. You are not going to get anywhere till it is replaced.
Give me enough duct tape and I can fix anything!
Re: 96 saturn sl
08/12/2010 1:30 PM
So its not my upper arm bar or the pressure plate or a sensor that's what everyone is telling me
Re: 96 saturn sl
08/12/2010 1:33 PM
The components you listed are part of the clutch. If you replace one peice but not the whole thing, you are going to have sreious problems.
Re: 96 saturn sl
08/12/2010 1:40 PM
I knew they were but I did not know for sure now I know so thank u very much for your info it was very helpful
Re: 96 saturn sl
08/12/2010 1:48 PM
The driven plate is the replaceable part. it is squeezed by the pressure plate into the flywheel at the output shaft (back) of the motor.
If you "ride" the clutch it will wear out much more quickly.
It's possible there is a bent arm, but doubtful.
Good luck.
Re: 96 saturn sl
08/12/2010 2:15 PM
Thank u very much 4 the info the pic even helped out more 4 I know where everything is when I fix it
Good Answers: 74
Re: 96 saturn sl
08/12/2010 11:07 PM
Good luck 2 u!
Bruce
Re: 96 saturn sl
08/12/2010 1:01 PM
I concur with Dr. farmatt's diagnosis. Apparently you didn't like my response to the other thread?
Good Answers: 299
Re: 96 saturn sl
08/12/2010 1:12 PM
Three votes for burned up clutch. Tow it to a transmission shop. They can fix it for you; not really a big deal.
If you disagree or want a different opinion, simply start another thread.
Re: 96 saturn sl
08/12/2010 1:26 PM
Snark Snark!
Re: 96 saturn sl
08/12/2010 1:36 PM
So its not my upper arm bar or my pressure plate or a sensor like everyone has been telling me
Good Answers: 179
Re: 96 Saturn SL
08/13/2010 7:06 AM
Another vote for the driven plate (ie, "clutch plate"). While it's being replaced have the mechanic thoroughly clean the pressure plate and the interior of the transmission bell housing, making sure that all the clutch dust is removed. Probably it's not a bad idea to replace the "Throw-out bearing" as well while your at it.
Good luck with the repairs!
Register to Reply 12 comments
ba/ael (1); CaptMoosie (1); Doorman (1); farmatt (2); lyn (3); moonlight_angel2u (4)
