Previous in Forum: What Does MODBUS Stand For?   Next in Forum: Difference Between Free Contact and Dry Contact?
What do DP and PROFIBUS Stand For?
08/16/2010 6:51 AM
tell me exactly what does DP means and stands for? what is profibus?
Re: DP and PROFIBUS
08/16/2010 7:33 AM
Hi,
PRO-FI-BUS -DP -------- Process Field Bus -Decentral Pheripherals
I think now everything must be clear to you .
“Reality leaves a lot to the imagination.”
Re: DP and PROFIBUS
08/16/2010 8:15 AM
To muddy things up a bit, we also must consider Profibus PA. (Process Automation)
Re: DP and PROFIBUS
08/16/2010 8:35 AM
DP also stands for Differential Pressure.
Re: DP and PROFIBUS
08/17/2010 12:23 AM
Not in this case at all , It is used in Siemens Sematic PLC , they use Profibus DP , and you have to configure the DP , Keeping in the mind that it is same as Centralized modules.
Here instead of arranging Modules in the rack you assign DP sations (Profibus nodes ) toa DP MAster. (Mater -Slave )
Re: DP and PROFIBUS
08/17/2010 3:30 AM
The question was asked in the instrumentation section, though!
Re: DP and PROFIBUS
08/17/2010 6:27 AM
OK buddy . no issues
Actually there are two community
1. Electrical and Instrumentation &
2. Control & Instrumentation.
In the frist one, people Consider Automation as a IT solution part , however the second one have to consider it ,in as there job inspite of from Electrical and Instrumentation dept .
It happens ! even me also trying to devlop these skills a bit .
Register to Reply 6 comments
omsumitam (3); Phys (1); PWSlack (2)
You might be interested in: Stands and Supports, Sheeters
