Can butterfly valves be used as Emergency shutdown valves ?
As far as i know, In general , Full bore ball valves are used for Shutdown purposes as the Bubble tight shutoff (leakage class VI) is possible with the ball valves.
Moreover the Tight shutoff is not possible with the Butterfly valves as the controllability is less with the flappers/waffers of butterfly valve.
Bu in one of the proposal that i am working on, Client used Butterfly valves as Shutdown valves for the services like Potable water, Process water.
Please clarify me whether butterfly valves can be used as Emergency shutdown valves are not. If possible, then what would be the leakage class for that valve.
