Previous in Forum: Wire Rope Drum Winding   Next in Forum: Callibration of CNG Tanks
Internal Painting for Diesel Storage Tank
08/19/2010 1:18 AM
Do we need to paint the internal surface of disel storage tank?
Good Answers: 141
Re: Internal painting for disel storage tank
08/19/2010 1:44 AM
Diesel itself will not corrode the tank from the inside.
These tanks however have mostly an aeration on top and water condensation will occur below the diesel in the tank.
If you make a visible drain point at the lowest point, you can tap the water and prevent the rust.
Depending on where you live, other regulations may apply such as double wall, liner when buried and other.
You can also work with a water separator in the tapping line. (demand)
Plenty of room here
08/19/2010 5:23 AM
Not if it's made of: plastic, stainless steel, galvanised steel, aluminium, mild steel, etc.
Not if one cannot gain access to the inside and maintain forced ventilation while it is being carried out (confined space entry permits?).
If the accountants want it done, get them to do it.
Register to Reply 2 comments
You might be interested in: Storage Tanks and Process Tanks
