Previous in Forum: A/C or Ventilation   Next in Forum: Thickness of ASME/ANSI Low Carbon Steel Flanges?
Static and Dynamic Balancing
08/19/2010 12:13 PM
what is conclusion on experiment to investigate the static balancing using a moment of polygon construction and dynamic balancing of a system by calculating the position of masses along the shaft?
Re: Static and Dynamic Balancing
08/19/2010 2:02 PM
Well, as the experiment range for this piece of classroom equipment is nearly word for word your question (all three times), I assume you missed the demonstration.
Will none of your classmates let you read their notes? You need some better friends!
08/19/2010 6:48 PM
Turn that cutie up to full speed--Lab RiverDance!
