Previous in Forum: The Bible of Electrical Protection   Next in Forum: Loss of One Phase
Short circuit Calculation
08/23/2010 10:49 AM
Hi Friends,
can anyone tell me the easiest practical method for short circuit calculation..... please consider me a fresh engineer....
i hope u ppl will me......
India - Member - New Member
Good Answers: 164
Re: Short circuit Calculation
08/23/2010 11:28 AM
Many papers are there on the web, also in CR4. You can find by using the search window on the right.
Here is one paper : ect158.pdf
08/23/2010 12:49 PM
Reading a paper from the web is certainly one of the cheapest ways to produce a short circuit calculation but it is not the easiest. This may not even produce an accurate calculation because the reader has to understand and apply the correct information from any paper. (The Schneider Electric application note you cite though is an excellent paper.) The easiest method is to hire a qualified electrical engineer and have them do the calculation. By hiring an electrical engineer you'll even get the pedigree of the EE schooling to support the calculation.
Just my two cents and at no charge.
Good Answers: 164
08/23/2010 10:47 PM
i suspect that the OP is a fresh-from-college EE tasked with this job by his employer
08/23/2010 11:07 PM
Yeah, you maybe right there. But if he can't show the initiative to do his own search of our forum or to use Google, then a little embarrassment might do him some good.
08/23/2010 2:11 PM
you can also check this location
Good Answers: 244
08/23/2010 7:46 PM
08/23/2010 8:44 PM
determine/establish your system VA,voltage,Current and impeadance..the common method is using your tansformer ratings..then transform every connected load presented in their corresponding impeadances..and use a 3 phase fault calculation for this much easier and gives out the highest value of short circuit current..
take care of your seconds and the minute will take care of itself..
kvsridhar (2); msamad (1); redfred (2); rockraiden (1); wareagle (1)
