Previous in Forum: Carbon Emissions   Next in Forum: Convert PPM to lbs/gal
Nickel chrome or Hard chrome
08/23/2010 2:43 PM
Dear All,
Please explain which one is better
Nickel chrome
or
Hard chrome.
Regads.
thoughts becomes things.
Re: Nickel chrome or Hard chrome
08/23/2010 2:53 PM
Depends on the application.
08/24/2010 1:04 PM
Please tell me for which application nickel chrome
and which application hard chrome?
Please give some example.
Good Answers: 60
08/24/2010 1:12 PM
  1. York Multi Purpose V Chrome Bar York Multi Purpose V Chrome Bar features a hard chrome coating and a 35mm urethane grip designed for extreme comfort and control. ...
    www.dolphinfitness.co.uk/en/york-multi-purpose-v-chrome.../16124 - Cached
  2. Hard Chrome - National Metal Finishing Resource Center (NMFRC)
  1. Q. In a nutshell, can you tell me if there is any difference between decorative chrome plating vs. hard? I heard someone call decorative chrome plating, ...
    www.nmfrc.org/crarchive/Mar02e.cfm - Cached - Similar
  • PF Online Feature Article - Hard Chrome Plating on Plastics ... Again, 0.0002 inch of dense hard chrome on a large L/D ratio core with minimum draft can make enough difference in friction reduction that the core without ...
    www.pfonline.com/articles/050002.html - Cached - Similar
  • Chrome plating - Wikipedia, the free encyclopedia A typical hard chrome vat will plate at about 25 micrometres (0.00098 in) per hour. ... Industrial chromium plating, also known as hard chrome or engineered ...
    en.wikipedia.org/wiki/Chrome_plating - Cached - Similar
  • Industrial Hard Chrome Plating Specialists There is a difference in industrial hard chrome plating. Since our beginnings in 1988, High Tech Chrome Plating has focused our energies and our resources ...
    www.chromeexperts.com/ - Cached - Similar
  • Hard Chrome Plating of Gravure Cylinders, Gravure Magazine ... The gravure industry began using the standard hard chrome plating bath shortly after ... For example, an anode spacing of 2" to 15" can be used under normal conditions. ... and we will discuss these differences in some detail later on. ...
    www.plating.com/gravure.htm - Cached - Similar
  • [PDF] Hard chrome replacement options File Format: PDF/Adobe Acrobat
    difference between uncoated and soft Cd alternatives. ❑ Fatigue debit with harder alkaline Zn- ..... E-Chrome 864 chromate conversion coating ... Zn-Ni (acid and alkaline) can be H baked with the normal. 375°F for 23 hour bake ...
    www.hazmat-alternatives.com/.../Cadmium%20replacement%20options.pdf
    14 Oct 2003 ... OEM Hard chrome. 0.003". Wear resistance on new items. Rebuild hard Cr ..... Difference due to open circuit potential ...
    www.hcat.org/.../Cr-JSF_ESOH-TWI-Cambridge_UK-10-14-03.pdf
  • [PDF] Hard Chromium Alternatives Team Update - Improving Performance ... File Format: PDF/Adobe Acrobat - Quick View
    The Hard Chrome Alternatives Team (HCAT) is a joint effort by the defense .... testing showed that there was little or no difference between the chrome and ...
    www.rowantechnology.com/.../Chrome%20Replacement/AESF-EPA%20Jan%202000%20corr1.pdf - Similar
Good Answers: 60
08/24/2010 1:13 PM
Good Answers: 150
08/24/2010 5:03 PM
hard chrome is hard. so it is good for bearing surfaces that experience a lot of wear. 70 HRC is not uncommon. It is often ground to finish and looks black after grinding. very slick. you won't be able to grab it with a pipe wrench for example. lots of Hexavalent Chrome in the waste stream, very very toxic.
Decorative chrome is just that, decorative. It may peel off if used for bearing surfaces. Generally poor adhesion. pinholes are common. Tends to be rather slick too. Hex Chrome is also a problem.
Nickel (not nickel chrome, that is a misnomer) is primarily decorative. generally somewhat better adhesion to steel, but tends to form pinholes if not done right. not as hard or slick, not as "bright" as chrome more of a dull yellowish silver than a "white" mirror finish. cheaper than chrome, not as corrosion resistant. Some people develop a contact allergy to Nickel. Not as much toxic waste generated.
Who is John Galt?
08/25/2010 2:11 AM
So it STILL depends upon application.
08/25/2010 12:53 PM
Dear all, I want to get done on my packaging machine parts. Thank you'
Register to Reply 7 comments
Anonymous Poster (2); peterg7lyq (2); Rorschach (1); sandeep lokhande (2)
