Previous in Forum: Recycling the Subtract (Polymer)   Next in Forum: Stress Analysis
Coalescer/Separator
08/24/2010 1:48 AM
Would appreciate if anybody can provide information on the material spec. no for the vessel shell material used for water separators. Only info provided is FCS Group II Class C.
Thanks in advance.
Re: Coalescer/separator
08/24/2010 2:07 AM
Temperature?
Pressure?
07/30/2026 1:41 AM
Proper piping layout and flexible connection protection matter a lot for coalescer operation. Abrasion and excessive bending on connecting hoses often cause unexpected medium leakage in long-term service.
Lonsuctech LLC High pressure hoses, plug valves & piping components https://lonsuc.com
08/24/2010 2:35 AM
08/24/2010 4:46 AM
can anybody provide info on the material specs of the vessel? we do not have copy of API 1581.
Re: Coalescer/Separator
07/11/2026 6:58 AM
FCS Group II Class C generally refers to the material classification used in the project or company specification rather than a universal ASTM or ASME material designation. For water separators, the shell material is commonly Carbon Steel such as ASTM A516 Grade 70, ASTM A36, or SA-516 Gr.70, depending on the design pressure, temperature, and applicable code (usually ASME Section VIII Div. 1).
If your drawing only specifies FCS Group II Class C, you'll need to refer to the project's Material Specification (MS) or Piping Material Class/Engineering Standard, where this code is mapped to the actual material grade.
If you can share the project specification or the equipment datasheet, I may be able to help identify the exact material.
Location: 1942 Broadway St STE 314C, Boulder, CO 80302, United States
10/14/2026 5:26 AM
FCS Group II Class C is an owner/project classification rather than an ASTM or ASME grade, so there is no table to look it up in – the shell material has to be derived from the service conditions.
For a hydrocarbon/water coalescer at moderate pressure the usual choices are:
  • ASTM A516 Gr. 70 carbon steel, internally coated (epoxy or phenolic) where the water phase is present;
  • ASTM A240 316L where the water is saline or chloride levels are high;
  • ASTM A106 Gr. B pipe for smaller shell diameters.
If it is an API 1581 type separator, that spec fixes the element geometry and staging; the shell call-out then normally follows the project data sheet. Worth getting the FCS Group II Class C definition in writing from the client before ordering plate – that single document sets the corrosion allowance, impact-test requirement and NDE regime.
Register to Reply 6 comments
Anonymous Poster (1); bee song (1); deepakawasthi (1); inspectorjoe (1); mengbin (1); PWSlack (1)
