Previous in Forum: At Last Progress for Power Cells   Next in Forum: Relay Use for SCADA Interface with Circuit Breakers
9 comments
Permanent Magnet Based Generator
08/24/2010 11:19 AM
frends,
i want to design a permanent magnet based generator which should get energised by itself after initial start.
one way is to select a high capacity permanent magnet based generator which consumes diesel and run itself.second way is instead of a fuel battery is used to energise the rotor (permanenet magnet based)and it starts rotating using an external dc motor connected by battery.then the generator must produce so much energy that it starts supplying it to the same motor which had initially used battery to run the rotor.and whatever is the surplus electricity produced will be used for household activities.
thank you
Re: Permanent Magnet Based Generator
08/24/2010 11:27 AM
08/24/2010 12:26 PM
Some generators already have a permanent magnet to power excitation, its needed for fault clearing (Breaker Tripping) on higher quality gensets
08/24/2010 1:02 PM
You'd be better off attaching wires directly to the permanent magnet and siphoning off its electricity. Save money and don't use the rotor, battery, motor, etc. - the result is exactly the same in the end.
Good Answers: 183
08/24/2010 3:29 PM
Good luck to make a revolution in physics: power from nothing!
Better take a degree in physics to understand the IMPOSSIBILITY to do it.
08/24/2010 4:10 PM
Deja vu, all over again. I guess we will just do this thread or something similar every week. What fun!
I wish someone would just build one that works, so I can get off the grid.
Good Answers: 804
08/24/2010 8:56 PM
Ahhh... memories.
I asked this question of my Dad when I was in fifth grade. Instead of answering it for me, he challenged me to make one and prove it. I did so with small motors from my erector set (which as it turned out were indeed PM motors) and D-cell batteries because I had already learned (the hard way) that motors can become generators. When it failed to work, he made me try to learn why. The explanation resulted in a school Science Fair project explaining conservation of energy and why perpetual motion cannot work for which I won first prize. That by the way sparked my lifelong interest in electricity and motors!
08/25/2010 1:12 AM
I hope the Industrial Applicaion of the concept is 'BRUSH LESS EXCITATION'.
BNDas
08/25/2010 2:18 AM
This is always worth a look when designing this sort of machine.
Good Answers: 181
08/25/2010 12:41 PM
That's a brilliant site
Anonymous Poster (1); biswanath.das (1); JRaef (1); kramarat (1); Mikerho (1); nick name (1); norton850 (1); PWSlack (1); TonyS (1)
