Previous in Forum: Expedition Head Gasket   Next in Forum: The Correct Way To Lap Engine Valves In
9 comments
Engineering Fields - Electrical Engineering - seek knowledge
1990 Golf 2 Problem
08/26/2010 4:09 AM
I have a 1990 golf 2, its automatic and uses electric carburetor, the problem is that when I am accelerating or pressing down the accelerator pedal, it jerks and does that frequently.The fuel pump has been checked and certified ok, the fuel filter has been change also, and the carburetor has been look at and the technicians said its ok, the plugs has been cleansed.the problem still persists? Can some one tell me what to do next?
Re: Golf 2
08/26/2010 4:16 AM
i might not be the right person to comment, but i feel you also check the injection nozzles or the jets which feeds fuel in the cylinder chamber, may be those might be clogged and giving improper fuel feeding..........maybe
Nothing is impossible, even impossible says I M Possible
Good Answers: 60
Re: 1990 Golf 2 Problem
08/26/2010 11:17 AM
Good Answers: 16
08/27/2010 12:44 AM
I had a similar problem a year ago on my Nissan Skyline. After much looking around it turned out to be the Mass Air Sensor (MAS).
What was happening was that the computer wasn't getting a clear indication of the air flow into the engine and was varying the injected fuel supply to match what it thought was the quantity of air present.
This is the problem when you rely on something else to do your thinking for you.
BAB
Make it so.
08/27/2010 7:16 AM
have you checked secondary ignition? carbon tracked spark plugs or wires that are breaking down could cause this concern
Good Answers: 60
08/27/2010 7:22 AM
try replacing the spark plugs it sound like they are failing under presure
also get ht leads tested or better still replace these as well.
08/27/2010 10:51 AM
I thought there was a penguin on the telly.
08/27/2010 9:23 AM
I am not very familiar with VW engines, but if they use EGR, a dirty or stuck EGR valve can cause these symptoms.
Good Answers: 37
08/27/2010 10:51 AM
Where did VW still offer carburetors in 1990? The last one I saw was on a 1976 Rabbit (they were offering fuel injection as standard/non-optional on some 1968 models). And what is an "electric" carburetor?
On fuel-injected models of that era, the usual cause of the problem you describe is a tear on the underside of the rubber inlet boot above the airbox and ahead of the long duct. Undo the two band clamps, take it off, and check by looking toward a light as you flex it. Even duct taping (clean the surface first) can make a huge difference if that's your problem. This was so common that I would slide tape under the duct without even bothering to remove it when I got the stutter-step acceleration. Self-sealing silicone tape is better than duct tape, if you can leave it for 10 - 12 hours before driving again, BTW. Still, buy a replacement if it's torn.
The engine rocks fore-and-aft under load. This stretches the boot and opens the tear, drastically changing the manifold pressure and dropping airflow through the hinged control flap in the airbox; this reduces fuel supply to match airflow. The engine loses power, and rocks the other way, closing the tear, and now accelerates again. Any competent VW mechanic would have looked for this, though.
" Ignorance and arrogance have more in common than their last four letters. "
07/07/2017 9:08 AM
Have it towed to a local licensed vehicle recycler?
Register to Reply 9 comments
BlueAussieBoy (1); Brave Sir Robin (1); ddphillips (1); goathead (1); peterg7lyq (2); PWSlack (1); Ron (1); santy1980 (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
